EXPERTS, How to calculate compunded PSI #'s
https://ls1tech.com/forums/forced-induction/257495-compound-induction.html
It's all about pressure ratios. Say your first compressor (turbo or SC) has a PR of 3. That gives you 29.4psig of boost though this formula, assuming your at sea level (ie. 14.7 = Atm):
(Atm+Boost)/Atm = PR
For your second compressor your Atm would be the product of your first compressor (29.4 here) plus 14.7 (to switch it from a gauge pressure to an atmospheric pressure). So use the same formula above but with 44.1 as your secondary Atm. So with a PR of 2.5 for our second compressor, the final boost pressure would be 66psig. Now go tractor pulling!
