LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   How's this for ground clearance??? (https://ls1tech.com/forums/forced-induction/267435-hows-ground-clearance.html)
LT1-7 Jan 26, 2005 10:58 PM
http://65.254.231.111/picture_hostin...clearance1.JPG
We're finishing up a customer's kit with 2.5" up-pipes and thought you guys would like to see how much ground clearance we have. Note this car has been lowered 2". So no, running pipes under the K-member isn't as bad as what most people think
disassembled Jan 26, 2005 11:21 PM
Looks good. Keep up the good work! Is anyone planning on buying this kit so we can have some numbers posted? BTW i will be contacting you about a huge FMIC for a twin turbo setup.
Greg
CAT3 Jan 26, 2005 11:45 PM
Looks like it matches the level of the trans x member and the rear diff. Nice job. Can you post up pics of the same car, all kit installed, or has it been added to your webite?
Thanks
Charlie
WS-Sick Jan 27, 2005 12:15 AM
Well, if that is lowered 2" then I like it.
smokinHawk Jan 27, 2005 05:23 AM
when you say up pipe do you mean down pipe? or the pipes that come from the headers and go to the turbo exhaust inlet?
LT1-7 Jan 27, 2005 06:08 AM
I mean the pipe that goes from the headers to the turbo inlet. People call it so many different names I'm trying to just call it something most people won't get confussed with. Probably didn't do a good job did I? From now on, I'll call it the header extension. That should clear up all the confussion
Tiago Jan 27, 2005 07:25 AM
Ive been building kits with pipes under the K member for years, it works great, and never had problems with groudn clearearance, however there is always people that will bitch.
IMO though if I had built a set of headers, whats the point of going under? ;)
smokinHawk Jan 27, 2005 07:40 AM
that clears it up.
so how big is the downpipe then?
abadss Jan 27, 2005 09:01 AM
looks good, my car is lowered, and is the main reason for not going with a STS for now. kit is looking very nice, great job man. i cant wait to see some members installing these so we can see some numbers. keep up the good work
jmorgan Jan 27, 2005 09:14 AM
in this picture the pipe looks alot lower http://65.254.231.111/picture_hostin...o_turbo_07.jpg
also whats the deal witht he dual wastegates? 2 tial 44mm?
Tiago Jan 27, 2005 10:42 AM
I think it was different diameter pipe there.
I never understood why 2 WG either.
01SSRMS Jan 27, 2005 04:23 PM
Looks great. Now don't go under like the rest and I'll buy a kit from you this summer, hehe.
© 2026 MH Sub I, LLC dba Internet Brands
