Vertical Flow FMIC's Either Air to Air or Air to Water. Does any body make an I/C that has two inputs on the bottom 2.5" (for twins) with a single large discharge 3.5" at the top in the middle for our cars and can they be fitted...????? I will be using a pin-on hood in a drag car so cutting stuff wont matter... :) :) |
Originally Posted by redrumss Either Air to Air or Air to Water. Does any body make an I/C that has two inputs on the bottom 2.5" (for twins) with a single large discharge 3.5" at the top in the middle for our cars and can they be fitted...????? I will be using a pin-on hood in a drag car so cutting stuff wont matter... :) :) |
either phamspeed or griffin can make you what you want. |
| All times are GMT -5. The time now is 12:45 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
