Whats the best stroker (cubic inches) to build for boost
Originally Posted by JZ 97 SS 1500
With the right tuning and parts, yes its possible.
So what power can be had now with the blower you're talking about?
There's no need to let a certain octane gas hold me up. Its easy enough to get anywhere around here.
Lyle whatever you're doing for money I wanna piece of the action!
Keep your motor go lower compression, change the cam, and depending on which direction you want to go you can with a Vortech Ysi or ATI F1 or go with a T88 or GT42 turbo. Then you can have a little spray "just in case"
Turbo's definitely pull harder on the top end so that may be the way you want to go.
Got the bug again?
Got the bug again?
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
