custom single PTE88, truck manafold, air to water turbo set up about 20% done
Old 07-27-2005, 10:07 AM
smokinHawk's Avatar
Default custom single PTE88, truck manafold, air to water turbo set up about 20% done
ill probably never be done messing with this thing.
have alot to do, all has been custom fabbed by me, thanks to awsome parts at good prices from forced inductions, griffin, speed inc, and various used parts from board members.
after last fall i began tearing it apart for the new turbo set up, ran ito a problem of how it would cost about double, maybe triple of what i first thouhgt, so its been progressing slowly, still have to buy a water pump , tank and lines for the intercooler.
specs are 88mm turbo, truck headers, 2.5" primaries, 4" downpipe and still have the almost stock motor mounts(poly not solid), 3" inlet on A2W IC, 4" outlet to throttlebody.
going to be using 96lb injectors (low impedance) with mega squirt, but will probably keep my 42lbs and stock computer with HPT untill next year, to dail in what i have, and when i get time next year to install it.
cage will also have to wait untill next year. also using the stock T56, not sure on the clutch, i have my ram being tested at their factory to see if anythings wrong, if its ok, then ill prboably use that for a while as power levels wont be to high untill i change a few things like add my megasquirt, maybe add another fuel pump etc. just hoping for about 600rwhp, and alot later when i get it dialed in
going to be keeping ac, mouniting it on top, in the pics is my first attempt at a bracket for it, but am going to do something different, as i need a new compressor as the one i have now leaks, so i have to add it to the list of things to buy when i get money.
i need to add some more pics of the few things i have done but this is most of my progress.
http://www.cofba.org/users/smokinhaw...ly/grizzly.htm
Old 07-27-2005, 10:14 AM
777's Avatar
That's amazing. I haven't heard of anyone relocating the ac yet.
Old 07-27-2005, 10:18 AM
NKAWTG...N
StoleIt's Avatar
amazing!!!! but when stairing at the pics, wheres your wastegate?
Old 07-27-2005, 10:29 AM
smokinHawk's Avatar
nt all have them in there, i took some before i fabbged it.
look at the ones with the turbo installed in the front, its right below the turbo.
Old 07-27-2005, 10:59 AM
FastKat's Avatar
Is it just me or is that A2W huge??
Old 07-27-2005, 11:07 AM
Restricted User
NOSjohn's Avatar
In the first pic, is that your nitrous bottle ? Nice setup.
Old 07-27-2005, 11:15 AM
2000 Tran Zam's Avatar
its a helium tank, dont you know hes a clown as a night profession?
Old 07-27-2005, 11:33 AM
libertine1015's Avatar
Didnt want to cut out and refab the front support for the radiator??
Really nice work, must be great to have a TIG welder!!
Old 07-27-2005, 11:46 AM
smokinHawk's Avatar
i wanted the turbo facing that direction to get more then enough air so, the ex-fog light will have ducting to direct the air into the turbo, like them fast 6 second cars have.
i love my tig, also picked up a small MIG recently to help tack things and do light work.
Old 07-27-2005, 11:49 AM
SSU'S Vice Mod
sb427f-car's Avatar
Old 07-27-2005, 11:50 AM
smokinHawk's Avatar
might be to big actually.
i wanted the water side to be located on the other side, so i tried to work with it, but it might be 2" to big, gonna see if i can fit it in there by letting the fender bulge, but it it dont work ill have to sell it and do another one.
its designed to support over 1000rwhp.
Old 07-27-2005, 11:57 AM
SSU'S Vice Mod
sb427f-car's Avatar
Things are looking good. That downpipe looks like a sewer pipe. Where are you trying to relocate the AC too? Why didn't you try and stand the rad upright underneath the cross support like I've seen a few others do, to gain some clearence? It looks great! Once you dig into these cars with the bat. removed and that radiator stood upright...there is a fair amount of space to use.
Old 07-27-2005, 11:59 AM
SSU'S Vice Mod
sb427f-car's Avatar
That's the other thing I wanted to ask...are you doing anything for turbo support?
Old 07-27-2005, 12:07 PM
SSU'S Vice Mod
sb427f-car's Avatar
I think I just answered my own question as I see you have a bracket there welded to the frame to support the turbo. You have a pic of just the bracket?
Old 07-27-2005, 12:19 PM
JustAnIlluzion's Avatar
thats some great work
Old 07-27-2005, 12:29 PM
smokinHawk's Avatar
i have a bracket that can be bolted up, but i havent desided if im going to use it, those cast manafolds are stout pieces, so im not sure its needed.
it was made out of a exhaust strap.
i did stand my radiator up a little bit. but i just wanted it not so wide so i could duct the air from the fog light and have easy access with the filter, so the turbo has no problem getting air.
also i desigegned everything to be worked on easily, easy plug access, easy to get to everything, and fix or change anything if needed.
everything is alot easier to do then it was when it was stock
Old 07-27-2005, 01:46 PM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Looks good man, can't wait to see the final results.
Jose
Old 07-27-2005, 02:26 PM
red90cobra's Avatar
looks good....lots of good ideas
Old 07-27-2005, 02:28 PM
NA$TY-TA's Avatar
Looks awsome man...... your right... you have alot left to do........ and your right about projects doubling and even tripling........damn things....
Old 07-27-2005, 02:46 PM
SSU'S Vice Mod
sb427f-car's Avatar
Yeah, I saw that after the fact though I think I just came up with a way to make a support, but I wouldn't know how to get it attached to the turbo itself. It looks really good. How are you gonna get the DP to the other side of the car? Considering the exhaust travels the length of the car on the drivers side right? Or am I out of it today for that? Would you just run a piece of pipe like the y-pipe to that side of the car I guess?
