Is keying the crank nessasary?
Old Aug 8, 2005 | 10:03 PM
nvmy2000ss's Avatar
Default Is keying the crank nessasary?
Is this somthing perrty common to do when you start to get in the higher boost say 10-12 #'s? Is it somthing I should look into doing?
Thanks guy's
Old Aug 8, 2005 | 10:14 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
My crank is keyed.
I would for 10+ psi IMHO.
Old Aug 8, 2005 | 10:32 PM
kp's Avatar
kp
7psi and up I would do it, cheap insurance.
Old Aug 8, 2005 | 10:40 PM
Inspector12's Avatar
TT-TECH Veteran
A pin kit will work if your motor is in the car and runnig if you are doing a rebuild Key it etc... If not you can pin it and it worked fine for me until I did the rebuild etc...
Old Aug 9, 2005 | 08:47 PM
v8juice's Avatar
Is that a mod on a already installed 7 psi system that involves purchasing a "pin kit" or what? Thanks
Old Aug 9, 2005 | 09:40 PM
TT-TECH Veteran
ATI sells a pin kit and that is what I bought. It's kinda pricey, but the one that comes with the Magnacharger kits for the vetts won't work for the Vortech pulley (ATI Pulley) I don't know about the Pro charger kits pulley. I borrowed the one for the Magnacharger from MTI and it wouldn't work as the pulley apparently has a larger opening on the stock vette pulley than the one that comes with the Vortech kit. So just so you know there are two different Pin kits available and it just depends on what your pulley looks like as to witch one will work for you etc... Hope I helped you understand and didn't confuse you to much.
Old Aug 10, 2005 | 01:40 AM
Boostaholic's Avatar
My crank is keyed.
Blah! I run 10psi on a non-keyed crank!
Old Aug 10, 2005 | 01:48 AM
TT-TECH Veteran
Oh yeah you Turbo guys are just real funny LOL! I might join your way of boosting in the future we'll see what my set up does with a few changes first.
Old Aug 10, 2005 | 05:59 AM
2001WS6Vert's Avatar
My balancer spun and chewed up the crank snout when I had the stock Vortech kit. It was properly torqued and loctited. Pin it or key it.
