LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   Finally went 9's with vid (https://ls1tech.com/forums/forced-induction/385846-finally-went-9s-vid.html)
99t66ls1 Sep 25, 2005 11:04 PM
I finally got everything working went to the track for the first time with the bs3.
Vid: http://media.putfile.com/chad86
60 ft 1.57
1/8 mi 115.7mph
1/4 mile 130 mph
1/4 mile 9.97
I had to lift right around the thousand foot mark because the wastegate line blew off the back of the intake and boost started to climb fast. I think there is quite a bit more in it but they kicked me off the track so i guess i have to go get licensed etc. This was on 17-18 pounds of boost and still on stock 99 heads, only thing upgraded is the springs. Da that night was 7200 ft im going to try to make it down to a sea level track here soon to see what it will do there. Raceweight is 3900 pounds.
W8N2SQZ Sep 25, 2005 11:24 PM
Nice run man...that thing makes some power :devil:
Glenn
GrahamHill Sep 25, 2005 11:33 PM
Got any direct links to the vid I can d/l from?
Got Me SOM Sep 25, 2005 11:55 PM
damn you got your cheerleading section and everything.
got any underhood pics? your car looks like a beast man!
99t66ls1 Sep 26, 2005 12:05 AM
2 Attachment(s)
here are some pics
SScam68 Sep 26, 2005 12:30 AM
Nice job, especially considering the altitude!
gnx7 Sep 26, 2005 12:51 AM
DA of 7200ft and your car weighs 3800lbs and you still run a 9 second time letting off?!?!?! :drive: Nice job bro!
What is the buildup on the bottom end? I assume a TH400 backing it up?
99t66ls1 Sep 26, 2005 01:21 AM
Diamond pistons, pro mod rods, thats about it still stock mains and bolts, yes it is a th400 the six speed didnt like the power to much so i switched over a couple months ago.
Moparnos (The SLP Guy) Sep 26, 2005 11:13 AM
what suspension are you running looks like your bouncing around alot
ls1CANTU Sep 26, 2005 11:55 AM
Nice.
Tiago Sep 26, 2005 12:46 PM
very nice!
I have a very similar combo, stock 99 heads and cam only upgraded valve springs and the bottom end, hope to get similar results :D
NA$TY-TA Sep 26, 2005 02:55 PM
bad ass man........ now go and sit down because there is so much crap to buy to be legal for 9's....... im buying it now..... sucks.... but good at the same time..... awsome setup and track time...... when ya going back???
Kyle
The Sad Sep 26, 2005 02:59 PM
Way to go Chad.
blackz93 Sep 26, 2005 03:36 PM
Sweet!!
Can't tell much from the video though, kinda breaks up and shit.
69firebird Sep 26, 2005 04:00 PM
what all do you have to buy kyle??
ed
99t66ls1 Sep 26, 2005 04:56 PM
Moser 9", qa1 shocks, spohn tq arm and lca's both rod ended, airbag in right rear and stock springs, mt 28 1050w et drags, ya its pretty squirly down the track dont know if its jus tthe track prep here or not i guess well find out when i go to another track here next month. To go nines legally you need a certified chassis, 10 point cage, sfi dampner and flexplate, flexplate shield, trans shield, nhra competition licence, full firesuit, chute at 150, master electrical shutoff etc, im shure theres a few more i forgot but those are all the ones i currently have to do.
NA$TY-TA Sep 26, 2005 06:13 PM
ed
battery kill switch, SFI approved Harmonic balancer, SFI approved bellhousing, 10 point cage, window net, neck brace, fire gloves, shoes, double layer fire jacket...(makes old one no good) fire pants, different rating helmet, SFI approved flexplate, flexplate shield, Tranny shield, aftermarket axles...... and thats off the top of my head. :jest: .... ill go look at my list
I dont want any problems..... oh i almost forgot..... NHRA license, IHRA license if you race at those tracks and a certifacation for the chasis....... its a big spendy list......
Kyle
69firebird Sep 26, 2005 06:17 PM
Kyle
well I guess Im no longer shooting for 9's then
just dont want to keep spending, the bleeding has to stop somewhere.
ed
NA$TY-TA Sep 26, 2005 06:36 PM
ed
Its big $$ man.....
The cheaper Fire gear is .. ill break it down on what i have left.....
Jacket $151
Pants $151
Shoes $72
Gloves $63
Neck brace $30
Helmet $250
Sfi Balancer ATI is the only one for us $470
Flex plate $200
Plexplate shield $50
Bell housing With tranny... inc
trans shield $90
Chasis cert About $130
10 point chromoly cage $2k
License's cheap plus a fisical for NHRA
Axlea re covered in the new rearend....
Itll end some day.... :jest: :jest:
way off track here but good info to know.....
Congrats again on the times and awsome setup.
Kyle
69firebird Sep 26, 2005 06:41 PM
isnt one of the underdrive pullies SFI approved?
I swear that my pulley had a SFI sticker on it.
Ill have to go check once I get home
ed
© 2026 MH Sub I, LLC dba Internet Brands
