More Twin Turbo LT1 Pictures for your viewing pleasure.
Old 02-15-2002, 08:35 PM
LS1Tech Sponsor
Brady's Avatar
Default More Twin Turbo LT1 Pictures for your viewing pleasure.
I've got the system mocked up in the chassis now, everything fits! I'll be tearing it down this weekend and sending a bunch of stuff to Jet-Hot. I hope to be doing a final install in a couple weeks. Then all I'll need to complete the project is the fuel system..
I'm looking forward to the Power Tour, Harlan; we could have alotta fun! <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" /> <img src="graemlins/gr_devil.gif" border="0" alt="[devil]" />
www.wheelhop.com/twinturbo
laterz!
...Brady <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old 02-16-2002, 03:08 PM
turbolx's Avatar
Default Re: More Twin Turbo LT1 Pictures for your viewing pleasure.
It's looking really good so far. I'm looking forward to seeing it in person at the Power Tour, too. I'm sure Matt won't the only turbocharged small block there, although he's certainly got me covered for power. <img src="gr_images/icons/wink.gif" border="0">
Old 02-16-2002, 09:56 PM
Rock's Avatar
Two things:
1) You are a better man than I, that SOB's gonna be a knucklebuster! How's plug access?
2) I never realized it's possible to pull a motor without a lift! I bet that was a PITA, did you have the K member bolted to the floor jack some how? I'm beginning to fell ballsy! I always thought I'd have to get someone else to do my motor if the time comes but you proved me wrong! Tell me about how that went, I assupme you've done it with a stock K member and NA motor before?
Old 02-17-2002, 12:30 AM
Crazyquik's Avatar
That thing is gonna be a ride when you get it done <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0">
TH400
twin turbo LT1
FAST engine managment
J.
Old 02-18-2002, 10:08 AM
Tony@AirRideTech's Avatar
That is bad ***........ ! nice fab work!
Tony....
Old 02-18-2002, 01:47 PM
CHRISPY's Avatar
WOW!! Now that is an intercooler!!
VERY VERY Sharp!!
What is your motor combo? What turbos and how much boost?
How are you setting up the air intake?
thanks,
Chris
Old 02-18-2002, 06:40 PM
LS1Tech Sponsor
Brady's Avatar
Thanks!
Rock; I dropped the motor out with a cherry picker. I just sat it down on 2 floor jacks and rolled it out from under the car.. By myself.. Help would have made it easier <img src="gr_images/icons/wink.gif" border="0">
Chris Pippy! Damn man, an old timer <img src="gr_images/icons/wink.gif" border="0"> Shucks, I remember when you bolted that Procharger on your '95 Z28.. How times have changed..
Anyhoo, I've got a 355" LT1 (forged/splayed/etc.) 9.1:1 static compression. LT1 heads (GTP ported) basically a pretty mild setup, cam is 224/236 .536/.555 on 114 LS (hyd roller)..
The turbos are TE-60's (good for 1200ish HP)
Boost: As much as I want <img src="gr_eek2.gif" border="0">
I've got 3" pipes fabricated for air intake, the filters will be in front of the front tires (where twin intercoolers usually reside). The 3" pipes are heavy! I'm thinking about using the 3-1/2" ATI "dryer hose" as air intakes. I know it collapses some in the blower apps, but I have two turbos so each hose will only have to flow half the amount of air.. I'm not certain which way I'll end up going yet..
I dropped a bunch of stuff off at Jet-Hot today to get coated.. I'll be stylin
<img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
thanks again for the compliments <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
..Brady <img src="graemlins/gr_devil.gif" border="0" alt="[devil]" />
__________________
2016 Z07 Carbon
Old 02-18-2002, 07:31 PM
blackhawk2000's Avatar
WOW! Looks like you've been real busy Brady. That's certainly not the same car I remember! <img src="gr_eek2.gif" border="0">
Old 02-18-2002, 09:18 PM
LS1Tech Sponsor
Brady's Avatar
Yeah, alot has changed since last year... except my odometer <img src="images/icons/rolleyes.gif" border="0"> <img src="gr_grin.gif" border="0">
My car has NEVER moved since TA Jack dropped it off after I shelled the tranny in Chicago last year on the Power Tour... God I'm lazy...
I found the miss though, remember we stopped at some rest stop and Harlan put the Tech II on the car?.... Turns out I collapsed a lifter.. (it was a "good" Comp Cams lifter too, oh well)
You coming out for the Power Tour again this year?
...Brady -with low mileage '96 Z28
__________________
2016 Z07 Carbon
Old 02-19-2002, 05:48 AM
NoOne's Avatar
That looks awesome!
What are you doing about cooling? The intercooler looks like it will block your rad pretty good.
Is this the TT kit for the LT1 that is planned for sale or are you just doing this for yourself?
Old 02-19-2002, 08:27 AM
Well at least it wasn't anything major with the lifter <img src="gr_stretch.gif" border="0">
I would love to go back on tour again, but with the baby it may be a problem. If not this year next year he shouldn't have any problems traveling.
Old 02-20-2002, 09:53 PM
1CAMWNDR's Avatar
Aren't you worried about the possibility of the coating flaking off of the interior and damaging the turbine baldes <img src="gr_eek2.gif" border="0"> ???? Maybe just get the outside coated....
Old 02-20-2002, 10:16 PM
LS1Tech Sponsor
Brady's Avatar
Eric, the cooling should function pretty well. The intercooler doesn't block the air flow path, the flow path is still very close to the stock configuration. I went !A/C, so that should help some too.. Time will tell, I'm prepared to get a Be Cool radiator if necessary.
My kit is based on the twin kit that will be available shortly. I bought alot of my own stuff though.. Waylon did build the headers, the turbos are from John Craig (Limit Engineering).
Mike, nothing upstream of the turbos is coated on the inside, you're correct, you don't want to chance anything.
BlackHawk, come out if you get a chance, it should be fun.
laterz <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
..Brady
__________________
2016 Z07 Carbon
Old 02-21-2002, 11:02 AM
Well for some reason I only checked the latest update. I am truly amazed at everything you have done Brady! Simply awesome <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
Old 02-21-2002, 11:11 AM
CHRISPY's Avatar
Brady,
Those good old days with the 95 Z-28!
I still miss that car it was a blast <img src="gr_stretch.gif" border="0">
I can't wait to hear how your combo works out, I think the lighter intake tubing will work great in your application. Can you fit a 9x6x4 inch outlet conical K&N in each wheelwell area? That would flow some serious air!
you have a great setup cooking there, what are you doing for fuel and injectors/tuning etc?
Best of luck,
Chris
[ February 21, 2002: Message edited by: Chris ARE 360 ]</p>
Quick Reply: More Twin Turbo LT1 Pictures for your viewing pleasure.
