Notices
ati #5 kit putting out #3 ok on FMU 4 bigger pulley?
Old 03-13-2002, 05:02 PM
Default ati #5 kit putting out #3 ok on FMU 4 bigger pulley?
I have the ati base kit #5, due to my free flowing exhaust (I know a good thing and more HP) I am getting #3 boost.
My question is. If the fmu can support #5 boost then can't I get a slightly different pulley to go up to #4-5 safely on the fmu??
thanks!!
highgmc is offline
Old 03-13-2002, 05:22 PM
Default Re: ati #5 kit putting out #3 ok on FMU 4 bigger pulley?
you need to know how much hp your making now and have a good idea of how much you will be making once you pulley up. you will then have to calculate whether or not your fuel system can meet the demands. with that said you can probably get away with it by cranking up the fmu. while this solution technically works it's is far from highly recommended. the superior solution is to have enough pump and injector along with the proper programming to handle the cars fuel requirments.
hope that helps.
Blackbird is offline
Old 03-13-2002, 06:07 PM
Adkoonerstrator
XLR8NSS's Avatar
Yep, exactly what Blackbird said. If your planning on pullying up I would definately go the injector/programming/pump route.
I don't think the FMU was made to handle much more than the 5# kit. Even though your only seeing around 3# your making more power and that is what will dictate your fuel requirements, not boost numbers.
Johnnie
XLR8NSS is offline
Quick Reply: ati #5 kit putting out #3 ok on FMU 4 bigger pulley?
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
