simple cooling fan question... do the fans blow into the radiator(air from engine) or suck in air(suck through radiator)? also, how do i check, other than letting my car idle, for the fans to work? tia.... |
Re: simple cooling fan question... They pull air thru the radiator. I believe you can turn your a/c on and it will turn on fan/fans |
© 2024 MH Sub I, LLC dba Internet Brands
