Is 2 Garret T3's enough for an LS1? I am building a twin turbo kit for my WS6 and have a few questions. I had originally plannd to use 2 garret T3's for the turbo's, but now I am not so sure that they will flow enough air. Are they big enough, and if not what would you guys recommend? Thanks. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> |
Re: Is 2 Garret T3's enough for an LS1? what ar, and what compressor trim? Ryan. |
Re: Is 2 Garret T3's enough for an LS1? Do some shopping here http://www.turboneticsinc.com/ then look at the maps for the T3's http://www.turboneticsinc.com/comp_maps/fig1.html You'd need no smaller than a T3 super 60 to get the air. And then you'll have very little room for growth if you don't want to get way outta the efficieny of the compressor. Your better of w/ a pair of T04B's or a T3/T4 hybrid. The hybird gets you internal waste gates. Always nice <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> |
Re: Is 2 Garret T3's enough for an LS1? You really think I'd have to go with at least a T3 super 60? I was pretty sure (read: hoping due to price and avaiability) that T3's would be enough. Assuming they had .63 exhaust housing. I called turbonetics and they also recommended a T3 super 60. After I relayed my thought's on the price of that turbo, the tech said that with my low boost requirements (7 psi) there would be very little danger of overboost with 2 T3's. Also they would have to work a bit harder, but they should be fine. Anyone else? Man, it sucks when someone as knowledgeable as Harlan tells you to get the more expensive turbo. Thanks for the input Harlan. |
Re: Is 2 Garret T3's enough for an LS1? If you think those T3 expensive look at a gt2535 that is on the Incon kits. Each CHRA cost $590, plus compressor and turbine housing, plus actuators, etc. Whats a complete T3s running for these days $700-800 max. Just remmember when you "push" the T3 harder you will be in a less efficient area and you will create more heat, heat it bad. Its all about trade-off. You have to look at what boost, flowrate and efficiency you want and go from their. Gary |
Re: Is 2 Garret T3's enough for an LS1? Yep I've been eyeing a nice pair of water cooled T04B's for a project i have in mind. about 25 lb/min each at 1.7 pressure ratio. Right in the center island with room to grow. It's all a trade off, cheap turbos and expensive intercooler, or better sized turbos and mid range intercooler. Or big turbos and big intercooler <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> |
Re: Is 2 Garret T3's enough for an LS1? Harlan, those wouldnt be for a truck would they <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> What did you end up doing to the gt2535s you had reworked? Did you do a little machine work on the compressor/turbine housings? Gary |
| All times are GMT -5. The time now is 04:56 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
