What injectors do ya'll use??? I was wondering what size injectors do ya'll use? My buddy at work said that the 8.1 injectors, which are 31 pound, will not support 550hp. I was also wondering when is it time to update the stock fuel pump? |
Re: What injectors do ya'll use??? Well im using the 42lb svo's think there rated around 600rwhp, well the guy who owned them before me pushed them to 576rwhp |
Re: What injectors do ya'll use??? myself and 2bseen use the foed/svo/green 42# injectors. |
Re: What injectors do ya'll use??? lol...started wiring up the 83s on Sunday...should finish up when I get home on Saturday! Prior to that 38 lb/hr. Scott |
Re: What injectors do ya'll use??? Thank you for all the responses. How much do ya'll think 31# injectors can support? |
Re: What injectors do ya'll use??? </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by truck: <strong>Thank you for all the responses. How much do ya'll think 31# injectors can support?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If your talking boosted horsepower than not much, maybe just a little over 400rwhp before they go static. Here is a fuel injector calculator. http://www.rceng.com/technical.htm#WORKSHEET Just going by your name I'm assuming these are going in a truck. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> The car injectors have different plug harnesses and might be a different physical size also(not real sure about that). Parish8 over in the truck forum got some 41# injectors from www.rceng.com that are a direct swap in the trucks. I forget who but, somebody else cut and spliced car harnesses onto their truck so they could use different injectors. Do a search over there and you'll find the threads. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> John |
Re: What injectors do ya'll use??? I am using 50 lb MSD injectors. Gary |
Re: What injectors do ya'll use??? yeah, those ones that parish bought for his truck were direct replacements. BUT... if you try hard enough im sure you could modify your fuel rail to sit a little higher and then just buy the harness adapter from shaun (valvegod) to use ls1 style injectors on the truck. btw, i have seen it done before, so i know it can be done <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> |
Re: What injectors do ya'll use??? What #injectors come stock on a 2000 formula LS1? I've got a 5psi procharger > should I change my injectors? If yes, what # injectors should I go with, and will my computer know what to do? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> |
Re: What injectors do ya'll use??? Cool!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Yes these injectors are going into a truck. LS1, small cam (205/212lsa116.5), ported heads, forged pistons 9:1, and a Vortech. I hope the fuel pump holds up. |
Re: What injectors do ya'll use??? </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by really slow truck: <strong>yeah, those ones that parish bought for his truck were direct replacements. BUT... if you try hard enough im sure you could modify your fuel rail to sit a little higher and then just buy the harness adapter from shaun (valvegod) to use ls1 style injectors on the truck. btw, i have seen it done before, so i know it can be done <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How did they do that?(Lift it up higher) Since the injectors go in opposite directions on the drivers and passenger sides it seems like the crossover would have to be cut and spliced with some hose or something so the rails would line up with the injectors. John PS - truck, it sounds like you got a cool project in the works. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <small>[ September 07, 2002, 02:12 PM: Message edited by: XLR8NSS ]</small> |
Re: What injectors do ya'll use??? I also have 50 lbs injectors |
| All times are GMT -5. The time now is 07:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
