LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   What AFR's do you run? (https://ls1tech.com/forums/forced-induction/398498-what-afrs-do-you-run.html)
speedz06 Oct 21, 2005 09:14 PM
I'm at 12.4-5 at WOT at 8 psi whats the norm?
Ryan K Oct 21, 2005 09:31 PM
LOL, AFR 225s!
But seriously, thats about right
NYSS Guy Oct 21, 2005 10:00 PM
Doesn't that sound a little lean for an FI setup?? I'm shooting for around 11-11.5:1 when I finally get to the tuning part.
Jaegermeister2k Oct 21, 2005 10:14 PM
I would thuink you wanna stay alittle under 12:1.
Ed Blown Vert Oct 21, 2005 10:32 PM
I sure would like to run close to 12:1. I lost 30 rwhp going from 12.0 to 11.5
Ryan K Oct 21, 2005 11:15 PM
Yeah you are right, I try my hardest to keep the AFR right at 12:1.
EPP Oct 22, 2005 06:03 AM
A forged bottom end can withstand 12.0/1, but we tend to shoot for 11.5/1. If it was on my own car, then I might lean it out a little, but I don't want to do that on a customer's engine, #7 always seems to run a little leaner anyway. Bob
Zombie Oct 22, 2005 12:43 PM
11.0:1 for me and anything I tune thats turbo or supercharged, especially on stock motors. Want more power, add more octane and turn up the boost, much safer than leaning it out. Leanes I will run a car is 11.5:1.
Another reason I tune 11.0:1 on 91 octane is when you start adding leaded gas with a lower specific gravity it will lean out. I know I go from 11.0:1 to about 11.3-4:1 using 100LL which I run quite often.
speedz06 Oct 22, 2005 03:10 PM
thanks guys-I get a little black smoke as it is at 12.5 the car was probably a little richer but I went to a slightly smaller pulley before I put in the guage.This is still the mail order tune from lingen wich I've run for 3 years.So now I can use a higher concentration of methanol to water knowing that I am on the lean side of things.I had no idea FI cars liked to run so rich.Now for my next question--I added a 100 wet shot powerring setup.I'm going to look for KR on the scanner,watch fuel preassure,and the AFR's I will try to keep???About 11:1??BTW,I have Ross forged pistons otherwise stock bottom end.
© 2026 MH Sub I, LLC dba Internet Brands
