LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   T3 turbo's (https://ls1tech.com/forums/forced-induction/39944-t3-turbos.html)
sleepybu Jan 5, 2003 08:29 PM
T3 turbo's
what's the diff between O, P, and Q trim compressor wheels
Also about how much HP will 2 T3's (60(trim) compressor .82 a/r turbine) suport on a 355?
y2khawk Jan 6, 2003 05:26 AM
Re: T3 turbo's
I'm guessing you mean the trim on the turbine not the compressor. The different trims for a given A/R housing will change the flow capacity and possible turbine speed you can reach.
Problem is, even 60 trim T3's will be too small for you. Even at 7 psi you'd be way off the compressor maps for both the standard 60 trim and the super 60. On a reasonable 355 setup you'd need about 30 lb/min from each turbo at 7 psi, that's way off the usable efficiencies for any of the big T3's.
You're better off looking for a pair of T04's
© 2026 MH Sub I, LLC dba Internet Brands
