Re: How's this for a blower cam? 228 seems like a bit much duration on the exhaust side, given 220 on the intake, for a blown LS1 application. What's the lift? It might be better to run a combination of a just a little extra exhaust lift, and a little extra exhaust duration, then to have that much difference in the duration. The 114LSA should be good for the blower, though. Have you checked out Thunder Racing's "blower" cam? |
How's this for a blower cam? Specs: 220/228 (XE lobes) 114 lsa. Considering it for a blown Z06 with headers and intake. How would something like this idle and perform? Thanks |
Re: How's this for a blower cam? looks good,cam should work good with your set up, sounds like she'll be a beast. |
Re: How's this for a blower cam? Thanks guys, the lift numbers are 0.564I/0.571E. Any ideas how the idle would sound compared to stock? The only restriction in the exhaust is random hi-flow cats. I want some lope, but I don't want to get a 112 lsa because of the application. |
| All times are GMT -5. The time now is 03:12 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
