Final Pump gas numbers from FMS
Tuned for 11.0:1 on a dyno jet = 11.5 on the road.
He told me I can run it on the street here without any problem, so I trust his judgement.
here are just a couple of pics...
great great numbes, I hope I can get close to that.
The GT55 is a 91.5mm turbo.....
Only Pump gas???? Why no C16 pulls???? Thats awsome HP though for Pump gas and really low boost..... awsome....
Stock PCM also correct??
Kyle
You can't run that lean on an FI motor on pump gas and be safe. Something bad will happen (detonation). Have him richen it up a lot, shoot for 11.0:1 on a dynojet. If he thinks that a 12.5:1 a/f is safe on pump gas you need a new tuner. I'm hoping there is more to the story like the wideband reading was off or something.
That 12.5:1 a/f will go to 13.0:1 a/f on the street i real world conditions. 12.5:1 is even pushing the limits when running c16. You have a lot of money invested in a bad *** setup, don't lose it all to a bad tune, i've seen it happen too many times on here and in person.
MY dyno reads .7-.8 lean so the 12.6 A\F is actually 11.8-11.9 A\F. I can run this kind of A\F due to the combustion chamber design,cam design and the big *** intercoller up front along with the efficient turbo. The intake air temp is located in front of the T\B and in these dyno test only gets 5-10 deg over oustside temp. If I was to dyno at 11.0-11.2 I would be blowing out black smoke like a diesel. This motor was built as a pump gas setup from the beginning. My N\A motors make the best power at 13.8-14.0 on my A\F display.
Now this is JUST a dyno test for now and IS NOT the final tune for the customer! Final street tuning is next.
Do any of you that preach 11.0-11.2 actually READ the spark plugs to see what is going on in the motor?
No pulls on c16 yet because hes been working his *** off with not only my setup, but a bunch of others as well.
I wonder if in the email he sent me it was a type, maybe he meant 11.6?
I dunno, maybe he can come in here and give us more info on it.
