what can you do to move oem radiator forward some
PurEvl is that the stock Rad as well as the condensor? That is exaclty what I want to do and like Dragframe stated, use some metal straps to pull it forward. Any other advice?
Good to hear, I may go ahead and try to do this in the next few weeks. I have plenty of metal to mess around with. I thought about trying to angle the condensor and A/C more straight up instead of the factory style angle they set at originally. Any thoughts on this?
Originally Posted by PurEvl
here ya go
One thing though is that Kyle had to use a shorter radiator and you did not.
That leads me to believe that you must have done something with the lower support to make that work, but I cant tell in your pic.
Either that or you angled it more to make it work
In which case it would be too far forward of the factory air scoop for it to do its job of channeling air into the condensor/radiator...
Could you provide some more pics please?
Oh, and how did you get the lines to the condensor to work out?
>EDIT< Subsribed!
and another with the final setup, hope these help guys...as for the cooling, my car runs about 190 in 100 degree heat, i rarely see my high fan on even after a wot run...i think its working
Originally Posted by NA$TY-TA
OR........................
You can do this.....
And just move the whole support forward................
Kyle
Kyle
lets get one thing straight kyle, i hate you, and i am not your friend. so take your perfect dream race car and leave tech as im tired of seeing pics of it.
i want one
heres another before i moves the turbo
What kind of issues did you run into with the lines going to the A/C condensor? Since its been moved so much...
Thanks in advance
