to MAF or not to MAf that is my question
Its the last post
shut up
that helps with the first part of my question
still dont know what MAF is the best?
oh he buys his first turbo kit and now he is a expert!
just kidding
no idea why youd keep the maf...go 2/3 bar. end of story. if running under 15 psi of boost, you can get a cobalt ss map sensor, plugs right into the lsx intake with no mods and you just plug the pcm harness into it. the 3 bar is trickier as you need an adaptor harness as well as you have to run boost refernce into it, you cant plug it into the manifold.
ok guys
i will loose the MAF and go with a 3 bar set up...
need to learn more about this ****..
i sent a message to leo at gmr speed that shop is the one thats gonna be tuneing this beast
one last dumb question i will be ordering a 3 bar map sensor through jj's automotive
one of these
GM Style 3 Bar Pressure Sensors
Manufacturer Part Number
GM (old)* 16040749
AC Delco (old)* 213-101
GM (new)** 12223861
AC Delco (new)** 213-1562
MSD** 2313
MSD (compact)** 23131
Borg Warner** EC1678
NAPA CRB219481
Electromotive Engine Controls 71130
Holley 538-23
THIS IS all i need this will plug right in where my stock 1 bar map is???
will the tune greatly vary with SD if its tuned for 95 degrees/60% humidity and then you run at night when it drops to 80 degrees at lets say 30-40% humidity.
I'm interested in trying this but our weather changes and I want that safety margin of the MAF.
We also have IAT sensors. In stock form they can adjust timing depending on weather. You can even put a resister in the sensor to trick into seeing a certain temp...that's old school.
