What's a good A/R combination?
Old Jul 12, 2006 | 09:31 PM
Navy David SS's Avatar
Originally Posted by obZidian
Navy Dave: That is with the 408ci right? Can i ask why you didn't go with a larger turbo?
Spool time. I built the car to drag race. Figured we could get the twin 67's to spool at 3500-4000 - which it does. My drive train will not take much more than the 1000rwhp that my car is tuned for. The twin have a capability of making 1200-1300 rwhp with the 408. If we now get the suspension and traction figured out, we will be in the 8's -- mid-to low 8's
David
Old Jul 12, 2006 | 11:17 PM
obZidian's Avatar
Originally Posted by nitrorocket
You have a 408, he has a 346. That makes a good bit of difference for A/R needs.
plez dont take this the wrong way but i believe he has a 408ci, that is why i asked about his particular turbo selection...
Old Jul 12, 2006 | 11:23 PM
obZidian's Avatar
David
By "spool" do you mean peak boost or initial boost? (kinda stupid question but i can't help it sometimes )
Do you think that if i ran a set of the super t70's or t72's with a similar .96 a/r, I will have peak boost before 4500rpm or at 4500rpm.? I ask becuz i want to have a turbo selection that will maintain my power levels in the future without having to spend the same dollars twice. I also want to run a a2a setup. Im also not 100% sure that my 4l80e will take more then 1000rwhp but i would like to see if i can.
What are you gonna do for suspension? You seem to be doing well, those track bars come i handy?
Old Jul 13, 2006 | 08:54 AM
PPI Typhoon's Avatar
So if I have a plan to take the T76GTQ off my Typhoon and throw it on an LSx motor....is the .85 A/R not going to work??
Old Jul 13, 2006 | 08:56 AM
DrTurbo's Avatar
LS1TECH Sponsor
An .85 is an on-center housing. I don't think I would want an .85 on-center on an LS1. Tons of backpressure.
Old Jul 13, 2006 | 09:22 AM
Thanks for the response.
So try to swap out the exhaust housing with a .96?
I've never modified any of my turbos so pardon if that's a newbie question
Here is a shot of the housing, does that not look like tangential? (serious question):
Old Jul 13, 2006 | 12:30 PM
sytyjedi's Avatar
Hey Dan, I switched to a .96 on my PT67 for the LS1. I can't see your pic (my network) but I can send you some pics of before/after. It's very easy to swap housings.
Old Jul 13, 2006 | 01:54 PM
I'm talking about initial spool. At 4000, I'm see about 3-4lbs, at 4500 will see close to 6-7lbs. We'll eventually be launching at 4200rpm's - about 6lbs.
I'm no turbo expert. Maybe someone can help on the 70 or 72 spooling. My builder/tuner recommended the 67's and so far so good.
Ask your builder of the 4l80e wheather it will or will not take 1000. I know I am concerned on my T-400. It was built for 1K but you never know.
Suspension. Hopefully I'm done with it. C/M K-mem & A-arms, w/QA1 shocks and their race spring in front; Wolfe race sway bar, 1 off custom TQ arm, QA1 shocks and stock (shortened) springs in back. Best so far on very very little boost 1.41; on nitrous with same set up did a best of 1.34 on a 200 shot. I guess the weekest part of the entire car is the original/stock backs front and back
David
Old Jul 13, 2006 | 04:13 PM
nitrorocket's Avatar
That is where the major difference in A/R comes in. For comparison, You get 7 psi @ 4500rpm..........My 347 with .68 A/R gets 16 psi by about 3500 rpm.
I mentioned this just for a comparison.
Old Jul 13, 2006 | 04:27 PM
Ari G's Avatar
Really?? I'm running twin 67's with .96 A/R. Boost comes in at about 3500, carries to red line (what ever I want, right now 6800, but easily could be 7200). No problems what so ever on getting boost. NO LAG. Launch off trans-brake is fun again. My HP and times are in my signature.
David
I like your setup,i´m going built LS1 with twin T70 with 1.05 A/R and 383 to 7000rpm
Hoping for around 1200-1300hp crank
Old Jul 13, 2006 | 04:37 PM
MiaSSmaro98's Avatar
Guys Quick Question Wats The Diffrence Between The On Center And The Other Model?describe Please?
Old Jul 13, 2006 | 04:42 PM
  #32
ls1king000's Avatar
what psi is that at your redline/shift points/max boost?
thanks
eddie
Old Jul 13, 2006 | 05:03 PM
  #33
come someone answer my question look up^
Old Jul 13, 2006 | 05:58 PM
  #34
Ok, well that's good news. This is the turbo I got from Nolan up in Canada. Ball bearing center section T76 for $1000. I would hate to have to give it up.
Where is a good source for housings??
Also pics would be great.
hanisch_dan@hotmail.com
Thanks for the response!
Old Jul 13, 2006 | 10:10 PM
  #35
On center is a housing where the exhaust inlet is centered wit the centerline og the turbo shaft. Tangenial is offset and give the exhaust a straight shot directly to the turbine. A Tang housing is supposed to be good for 5-10% more power. The downside is that you cannot mount the turbos with a symetrical look. One turbo will sit way up and one way down, unless the headers are built to accomodate. But then you still don't have a symitrical look if thats what you want.
Old Jul 13, 2006 | 10:13 PM
  #36
can u post a pic of the diffrence?
Old Jul 14, 2006 | 08:48 AM
  #37
DrTurbo's Avatar
LS1TECH Sponsor
Call us we can get you any housing you need.
Old Jul 14, 2006 | 08:56 AM
  #38
sytyjedi's Avatar
I got my housing from ya'll and would recommend anyone else do the same.
Dan, I got a T4 tang undivided housing, T4 flange, v-band clamp and starter section for the downpipe from Forced Inductions.
Old Jul 15, 2006 | 01:19 PM
  #39
Cool thanks, I'll keep that in mind.
