What's a good A/R combination? hey i'll be shopping for a turbo soon but i wanna know wat AR combination is everyone running.im looking at t70's. more then enough,but wat AR should i pick?the car is a 98 ss all stock with an automatic tranny and it will be a daily driver.i want around 500rwhp and nice strong powerband all the way through 6500 rpms |
You want to go .96A/R. |
What a/r for twins? Innovative or gt40s stock motor now later 370, 6.0 heads 3.10 or 3.20 gear |
.96 on the exhaust turbine correct?wat about the front? |
I'm running a T-70 w/ a .96 AR turbo exhaust housing... You'll love it... With your tranny, you'll load up real quick better than me. :burn: |
Originally Posted by ls1king000 What a/r for twins? Innovative or gt40s stock motor now later 370, 6.0 heads 3.10 or 3.20 gear |
Originally Posted by MiaSSmaro98 .96 on the exhaust turbine correct?wat about the front? |
the compressor a/r is not as versatile as the turbine a/r. Basically, since the compressor side doesn't really change much in turbo dynamics, the turbo manufactures will leave it at a set "baseline". However, the turbine a/r is where the magic is at and where the a/r talk is guided at. The higher the ratio, the more peak power you will attain while compromising a bit of turbo response. The lower, well, you get the opposite.... Now, ppl are running a .96 single setup. On a twin, theoretically, you should expect that turbo to spool slower, corrrect? So, with a 408 twin setup, should you consider running a lower a/r (let say on a t70-t76) or stick with it .96 since the motor is also pushing alot more air per bank? I would like to match a pair of super-t's t70's or t-72's .96a/r. |
I have a pair of 96s on my turbine side and they spooled great |
i had the .96 and i could not stand it - big lag but it made good power on top end. i switched to a .81 and it is much more fun , quicker boost just great on my auto trans daily driver car. :hail: .81 |
A pair of 96's What What?? |
twin t-64s ceramic bearing 350 cubes .81 A/R turbines(on center housings) starts boosting around 3300rpm pulls hard to 7000 works good on the street. backpressure matches boost |
.96 is WAY too big for a twin setup, Use .68 housings. Also, t70 is way too klarge for only 500 rwhp. Use 60-1 hi-fi's or similar. |
How would a single T70 with a 1.0 AR go ? |
Originally Posted by smoke20 i had the .96 and i could not stand it - big lag but it made good power on top end. i switched to a .81 and it is much more fun , quicker boost just great on my auto trans daily driver car. :hail: .81 |
Originally Posted by Johnv How would a single T70 with a 1.0 AR go ? |
yeah i will go with the .96 that way i dont hit boost while driving like an old lady |
Originally Posted by nitrorocket .96 is WAY too big for a twin setup, Use .68 housings. Also, t70 is way too klarge for only 500 rwhp. Use 60-1 hi-fi's or similar. Really?? I'm running twin 67's with .96 A/R. Boost comes in at about 3500, carries to red line (what ever I want, right now 6800, but easily could be 7200). No problems what so ever on getting boost. NO LAG. Launch off trans-brake is fun again. My HP and times are in my signature. David |
Navy Dave: That is with the 408ci right? Can i ask why you didn't go with a larger turbo? |
You have a 408, he has a 346. That makes a good bit of difference for A/R needs. |
| All times are GMT -5. The time now is 09:57 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
