LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   What's missing? Vortech V-9 (https://ls1tech.com/forums/forced-induction/543531-whats-missing-vortech-v-9-a.html)
bradl1982 Jul 17, 2006 10:06 PM
I might buy this vortech supercharger. Here are the pictures the guy sent me
http://img.photobucket.com/albums/v3...ercharger2.jpg
http://img.photobucket.com/albums/v3...rReservoir.jpg
http://img.photobucket.com/albums/v3...dl1982/BOV.jpg
http://img.photobucket.com/albums/v3...tercooler2.jpg
http://img.photobucket.com/albums/v3...tercooler1.jpg
http://img.photobucket.com/albums/v3...ftercooler.jpg
Here is a list of all the things that vortech says is included with the kit.
V-9 G-Trim supercharger with air assist, SQ gears and 8-rib 2.95" pulley to produce approx. 8-9 psi.
NHRA legal aftermarket steel harmonic damper replaces the factory iron unit.
8-rib aluminum crank pulley to drive the supercharger.
Air/Water aftercooler assembly with pump, wiring, surge tank, reservoir and front mount heat exchanger for effective street operation.
T-Rex® fuel pump assembly with wiring harness.
Eight 38 lb./hr. replacement fuel injectors.
OEM style cast aluminum supercharger mounting bracket.
Automatic supercharger belt tensioner.
Compressor bypass valve
Cast aluminum discharge and air inlet ducting.
Oil drain, oil feed, air discharge and air intake assemblies.
Handheld ECM re-programmer
tool for modifying oil pan for supercharger drain fitting
I'm not seeing a handheld programmer, fuel pump, injectors or the crank pulley. Am I just blind? What else isn't in there? Thanks for the help.
JMBLOWNWS6 Jul 17, 2006 10:10 PM
Are you buying this for a LS1? Because that kit is not for a LS1. For sure 100%
OldBlue Jul 17, 2006 10:15 PM
Indeed, appears too be off a truck and or SUV.
Red97Z Jul 17, 2006 10:30 PM
does anyone know where I can pickup one of those conical filters for the bypass valve discharge outlet? I have a vortech bypass valve identical to that one.
JMBLOWNWS6 Jul 17, 2006 10:35 PM
HAHAHA What a trip. Im looking for one right now. Im running in SD and need one. Well when I put it back together :bang:
bradl1982 Jul 19, 2006 01:41 AM
Thanks for your help!!
© 2026 MH Sub I, LLC dba Internet Brands
