Well if its not one thing its another...
Old 08-08-2006, 12:09 PM
Zombie's Avatar
Originally Posted by 2000 Tran Zam
Haha, 3 speeds are no fun
You just haven't been enlightened yet.
Faster spool
better traction
better drivability
better 1/4 mile times
easier on driveline parts
brake boosting from a dig
No boost drop between shifts
th400, hallowed art thou name
Old 08-08-2006, 12:16 PM
2000 Tran Zam's Avatar
Faster spool
better traction
better drivability
Why not do a 4l65e or 4l80e? What are the major differences in it?
isnt parish running a stock 4l80e on his 1100 rwtq setup?
Old 08-08-2006, 12:19 PM
LSxChevelle's Avatar
Faster spool
better traction
better drivability
Even with all that I love slamming gears and dawnshifting!
Hopefully the break isn't too bad and you can heal soon!
Old 08-08-2006, 12:28 PM
Ya, I know the motor was running very strong cause normally I can hook in second.
I had about half a tank and filled up with 9 gallons of 101 before we went out.
Still on pump gas setting, but when you put down 830+ at the wheels, and even more before the drive train loss those parts take a beating.
Ill try to get some pics of the damage tonight.
as long as the car is gonna be down, Im prob gonna try to pull my manifolds and turbo and get it coated.
Might as well kill two birds with one stone right?
Old 08-08-2006, 12:51 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,175 Likes on 764 Posts
If you broke the output shaft, maybe PM Intmd8 and ask him about his beefed up T56.
Old 08-08-2006, 01:32 PM
smokinHawk's Avatar
ya how much money are you going to waste on clutches and trannies (im amazed mine has lasted - though im easy on it) i could have already paid for a th400 with my past clutches that didnt work.
but i figure why mess around, if you want to be fast put a Th400 in it and stop worring about stuff you dont have to.
Th400 FTW!!
Old 08-08-2006, 02:45 PM
Th400 FTW!!
lol, its a weekend car, and I havent even launched it yet
i know its fun and all to flasht he converter and hold on for dear life, but its not the same if you cant shift.
Plus how does it work with a BOV on an auto? Do you only release the pressure when you get out of it at the top of 4th or whenever you let off?
I like hearing it every time i shift
Old 08-08-2006, 02:46 PM
Ya Ill see whats wrong first and then I'll figure out who I need to contact (whether its intimid8 or g force or someone else).
Damn, couldnt have come at a worse time though financially speaking.
Old 08-08-2006, 02:55 PM
FormulaFire's Avatar
If it's the tranny. I would rec. T56rebuilds. G-force is only good to about 900hp. They don't use 300M and won't.. Which is what you'll need for that kind of power. T56rebuilds will warranty it up to 1300hp. Give them a call if it's the tranny. they're a sponsor. (888)937-4411
Old 08-08-2006, 03:12 PM
NA$TY-TA's Avatar
TH400 with a gearvendors overdrive unit...... its just as fun with a manual valve body.... u still shift it u just dont need to use your other foor for the clutch petal....LOL
Kyle
Old 08-08-2006, 03:51 PM
Zombie's Avatar
Th400 FTW!!
Join us
P.S. I too use to be a gear banger, until I got tired of spending money and time and labor on clutches.
I still have to manually shift my car, even have to push the clutch peddle to start it.
Old 08-08-2006, 05:39 PM
  #32
LTLHOMER's Avatar
th400/glide + 1
Old 08-08-2006, 05:50 PM
  #33
Mekkadon's Avatar
I wuv my TH400
Old 08-08-2006, 06:07 PM
  #34
BLk01SS's Avatar
He's running a GForce, IMO for your setup man you should go with one, otherwise this is likely to happen again.
Old 08-08-2006, 06:08 PM
  #35
Phate's Avatar
TH400 + GV is a great combo...hopefully my car will be back together soon and I can see if the GV can take the power.
Old 08-08-2006, 07:04 PM
  #36
NA$TY-TA's Avatar
Cool what one did ya go with??? How much id ya dont mind?? $2800???
What rear gears out back?? 28" tall tire???
Im wanting one sooner or later.
Kyle
Old 08-08-2006, 07:46 PM
  #37
I know that Futral did rebuild my t56, but I dont think he did anything with the input shaft.
Im headed home in about 20 min, so hopefully tonight or tommorow ill post up my findings.
Old 08-08-2006, 08:01 PM
  #38
qqwqeqwrqwqtq's Avatar
Hmmm, I'll have to check, but I thought my output shaft was 300M.
And fwiw, the G-force T56 has been behind much more than 900hp and survived.
Old 08-08-2006, 09:47 PM
  #39
Smearin's Avatar
I want to know how he noticed the car didnt do anything... but didnt even bother to check underneath the car to see if he had a driveshaft or pieces of the trans on the ground?
Old 08-08-2006, 10:39 PM
  #40
I believe.. don't quote me on this.. but G-Force used to use 300M, but now only 93-10.. I'm not saying it couldn't survive. but they only warranty up to 900hp. The 300M is undoubtfully better.. G-Force has some good products though. just call and shop around.. Liberty, G Force, etc etc. I was in the same predicament man.. My tranny recently went to crap and I had to decide whether or not to go with an auto or manual. They both have there pros and cons. A decision only you can make!!
Quick Reply: Well if its not one thing its another...
