T88 FM and a 370CI.....do you have this combo?
so i was curious how many guys are running a t88 and a 370 6.0 motor? what is your fully boosted rpms and how much power did you make?
t76 guys if you want to post as well remember im only asking for 370 CI motors and t76 or t88 numbers on pump gas and race gas or meth thanks guys
I will have a T76 on my 00 Z28 shop car soon. It has a 8.5:1 370 with ported and polished 6.0L heads. I will post up results when I get it finished. Hopefully this month is all goes as planned.
only a 347 cubed ls1 8.9:1 CR, but with a PTE88
sees 12psi about 4000-4200, 15psi a little over 4200
making around 700rwhp through an M6 with 15psi, about 620rwhp with 12psi (going by trap and weight)
should be making a bit more next season since i finally got 3bar setup and some 96lb injectors and then gonna boost past 20psi
Yeah i have a T6 Flanged 88....
Made 842rwhp thru a Glide and a 12 bolt..@ 17 psi.
My 9.26 pass was on 20 psi.....
I drive the car around on 14 psi everyday....Pump 93...
I start seeing boost a lil over 2k and my 4k im at full boost.....
I love the combo......
On the transbrake i can get 10psi before 4k
Kyle
Kyle
