What cam? T-76,ported heads,stock cubes.
Old 11-10-2006, 04:30 PM
phildo's Avatar
Default What cam? T-76,ported heads,stock cubes.
What cams are the big boost, stock cubed, front mount guys running? I now have a MTI Stealth I cam and MTI stage 2E heads. Just wondering if I should go bigger? The cam specs are 220/220 581/581 on a 115 lobe seperation.
Old 11-10-2006, 04:32 PM
Mr_president's Avatar
sounds like a great cam!!
Old 11-10-2006, 04:35 PM
TurboGoat's Avatar
I am going to run a 225/225 581/581 on a 113 with my 76gts and 317 heads.
Old 11-10-2006, 05:01 PM
99SS-T's Avatar
232 240 598 608 on a 115 here. Its nice!! lol. In FI u aint as tied to gettin teh biggest cam to make power as u are with NA. If u r all about pullin out all the stops then get a huge cam. GL man
John
Old 11-10-2006, 05:12 PM
NassyVette's Avatar
The cam you have looks good, but you can always go bigger.
Old 11-10-2006, 11:13 PM
i went 10.60s with mine and its like a 218 214 564 546 115 lSA AT 8 pounds...made 550 thought a nine inch and a 6 speed on 14 degrees of timeing!
Old 11-11-2006, 12:37 AM
deadmanTA's Avatar
228/228 588/588 114 with 317's here
Old 11-11-2006, 02:24 AM
ninetres's Avatar
got a dyno sheet (if so please give engine and boost level specs)?
Thanks.
Thats very similar to the cam I want for my turbo set-up.....if I ever decide to switch.
Old 11-11-2006, 09:09 AM
engineermike's Avatar
It depends on your goals. For max power on pump gas, I would go 230/236-114 or 236/236-115. However, if you are willing to use race gas or want a better idle, it's been proven that 218/218 or 224/224 can make just as much power but at higher boost levels.
Mike
Old 11-11-2006, 09:21 AM
black01_WS6's Avatar
I am going to be going with EPP's forced induction cam 232/240 595. 608 on a 115. My car will be seeing the street only on weekends and an occasional trip.
Quick Reply: What cam? T-76,ported heads,stock cubes.
