90deg fittings for heater hoses off of water pump
Old 01-28-2007, 05:00 PM
single digit dreamer
parish8's Avatar
Default 90deg fittings for heater hoses off of water pump
not sure if anyone had done this but for those fabing up their own stuff this might open up some options. i am working on a set up where i didn't like the heater hose outlets so i yanked out the fittings and put in some threaded 90's to get them where i wanted them.
to get the fittings out i heated them up till they were red and twisted them out with some chanel locks. the holes that remained were just the right size for a 3/8"npt tap and a 1/2"npt tap. i taped them and twised in the brass fittings.
Old 01-28-2007, 05:07 PM
otherwhitemeat's Avatar
yes..........you can use the aeromotive type fittings as well
Old 01-29-2007, 05:22 PM
SELLSZ06's Avatar
I needed the same thing, but welded 2 ss pipes of the same ID" pointing up. that should work... looks good
Quick Reply: 90deg fittings for heater hoses off of water pump
