STS Dyno!
Old Feb 17, 2007 | 11:30 PM
Tiger2o69's Avatar
Originally Posted by Schantin
The 9" is sucking a lot of power. That is a reason your HP number is much lower in the dyno results than the torque #.
I measured my IAT's at 5PSI before adding the FMIC. 130+ degrees normal cruising in Hawaii w/ around 85 degree outside temp and 80% humidity. Computer begins massively pulling timing above 100 degrees.
With the FMIC my IAT's have never exceeded 104, and that was driving the car like a total a$$. The STS intake pipe comes close to the driver side header, and the radiator/ power steering pump cooler lines. The intake charge picks up a lot of heat from these. Bottom line, you really DO need a FMIC, regardless of the BS STS puts out.
Just my $0.02
Notice the DECENT part... I agree.. I would do the FMI.. I was only saying that you dont necessarily have to have one like you would a front mount turbo..
Anytime you can cool the charge you can make more power and be safer.
Old Feb 18, 2007 | 01:27 AM
00WS6WHITE's Avatar
Well lets hope I don't wanna up the boost for awhile, it is not my daily driver soooo.... Im running 42# injectors with a walboro 255 lph pump.
Jimmy
