LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   ATI has two new systems for the GTO's!!! (https://ls1tech.com/forums/forced-induction/667597-ati-has-two-new-systems-gtos.html)
EPP Feb 28, 2007 07:34 PM
http://www.exoticperformanceplus.com...html?item=1070
2004 F1A system
http://www.exoticperformanceplus.com...html?item=1071
2005-2006 F1A system
Check them out above. Bob
sprayjunkie Feb 28, 2007 08:39 PM
Links not working?
SSilverSSurfer Feb 28, 2007 08:54 PM
yeah link not workin
98 Z28 Feb 28, 2007 09:04 PM
remove the '...html' for the link to work.
lol never mind that still doesn't work it just brings you to the home page..
Jake@EPP Feb 28, 2007 09:18 PM
Here is a corrected verrsion!
chuntington101 Mar 1, 2007 01:51 AM
what the aprox. max output of the F1-A????
thanks Chris.
EPP Mar 1, 2007 04:49 AM
http://www.exoticperformanceplus.com...er%20specs.jpg
Take a look at the chart above. You can see the F1A uses the same inlet and outlet diameters as the P-1SC-1 and the D-1SC. Max rpm is 12,000 rpm higher than the D-1SC, at 74,000 rpm! This blower has the potential to scream! Bob
EPP Mar 1, 2007 04:58 AM
Links revised. Thanks! Bob
misho911 Mar 3, 2007 02:34 PM
hi...
Is their procharger F1A for Trans Am 1999???
52172 Mar 3, 2007 03:35 PM
there is , but not as a package.
99Z28LS1 Mar 3, 2007 05:31 PM
:judge:
yep, you'll have to cut and remover thing to make that monster fit in there
EPP Mar 4, 2007 07:44 AM
http://www.exoticperformanceplus.com....html?item=798
We offer the F1A as an head unit upgrade option. Bob
misho911 Mar 5, 2007 08:11 AM
what is the maximum boost and what is modification engine required
EPP Mar 10, 2007 06:31 AM
You would need to have forged rods and pistons, a machined block, good rings, ARP head studs, and a completely redone fuel system such as the one we installed on this Trans-Am.
http://www.exoticperformanceplus.com...Car.php?car=42
The F1A is capable of making over 20 psi of boost, depending on your engine combination. Bob
David Gordon Mar 10, 2007 08:07 AM
How much better is the F1A over the D1SC? I am having Texas Speed install a D on my 395 and was wandering if it should be upgraded to a F1A?
EPP Mar 11, 2007 07:58 AM
The F1A is capable of making a lot more boost than the D-1SC. If you have a built engine with a forged bottom end, then the F-1A is the blower I would recommend for you, provided you are looking into making more than 16 psi of boost. Bob
© 2026 MH Sub I, LLC dba Internet Brands
