F Body intercooled twin turbo system - preliminary pricing $5495 inc free delvery
#1121
Originally Posted by bigblueturtle
Somebody answer this for me. If a car is tuned to run on a turbo system at 7psi, what good would it be to run a boost controller? Here is what I mean... I know people that change boost levels on their car while out cruising around. Wouldn't that make the car run too rich or lean depending on where the boost is set in reference to the tuning of the car? Why change it once the car is tuned?
http://www.jscspeed.com/index.html?/...m_truboost.htm
they can have multiple tunes which can just be downloaded to run high/differant boost levels.
#1122
I am not a pro tuner and I may not use the right terminology but if you use a different OS that allows for boost, it can be tuned for multiple boost pressures.
So if you change your boost at anytime the PCM along with the New OS will allot the correct fuel, air, and timing for the boost applied.
Someone please add or correct me if I'm wrong.
Hope this helps TNT and BIGBLUE
#1123
You can tune with speed density for different boost levels but you can also tune normally and be pretty close if you are not going crazy with boost changes.
Speed density is not the norm in turbo cars from what I have seen. Sure the big hp guys usually run it.
I bought hp tuners to give me the option to run SD. I had tunercat /jet also already for tuning my 96z and it might have worked on the twins but thought hp tuners was better. Still actually a bit disappointed in tuners. It has good forum support and complany support but its so generic it really has not implemented features that turbo guys want and need. Now maybe the ls1 ecu can't do them. The features I really wanted to see are two step launch or stutterbox as its called, anitlag, no lift to shift for stick cars to keep the turbos spooled and mabye some nitrous controls like built in window switch type of thing.
The only way to get this stuff might standalone not sure. At least can log afr with hptuners and would think obviously boost with SD option and you can tune in real time with the expaned maf or SD options. That is handy thing also.
Anyway sure I can make hptuners work for me. Good enough. Not building a track car anyway just a fun street machine.
#1124
Originally Posted by fil131
Hope you feel better soon peter.
Thanks for the update.
Filbert
Filbert
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks,
Peter
#1125
Both EFILive and HPTuners offer 2 and 3 bar tuning options. Check out the PCM tuning forum for LOTS of details and examples. Simply put, the factory PCM's allow the ability, through custom OS changes from both of these packages, to be fully boost-capable in either speed density or MAF modes. You're going to max out the MAF quickly anyway, so to me is simply makes sense to put it in the bin and tune the car speed density from the beginning. In fact, NOW would be a good time to start your SD tune, and get the drivability at <= 1bar nailed down. Once you install the kit on the car, you're just that much closer, and can concentrate almost purely on 1+ bar tuning.
With the car fully and properly tuned for a certain fuel, you can run a boost controller and set it to (nearly) any boost your heart desires. If you change fuels though, you're changing the rules somewhat. You would need to consider the new variables and set up your tune accordingly.
#1126
Originally Posted by DanZ28
Thanks Peter, but I did realize it fits with a 4l60E trans like in the picture shown. I've already been down the whole built 4l60E phase and know they don't hold large amounts of torque (I know it's a controversial statement but I've been there) which is why I now have a TH400 in the car. I know guys like me aren't your main target here, but I was hoping you might be able to test fit one or do some measurements. Don't want to buy the kit and have to modify everything
Thanks,
Dan
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Thanks,
Dan
Peter
#1127
Im also interested in the twin pump fuel system, any pricing info yet Peter?
I can hardly wait for the kit to come out.
Thanks,
Peter
#1128
Ryan
#1133
Originally Posted by Rubberduck
Peter,will aps supply a base tune for free like the other aussie company will do ? ![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
Tnx
Tnx
#1134
Originally Posted by SStolen
Has APS been daily driving this car with the A/C installed to see what kind of engine temps it's reaching? I was looking at the location of the intercooler and can't tell how obtrusive it is. I've seen cars with what look to be minimal obstructions cause the car to overheat like mad. With the radiator, air conditioner and intercooler in the same location, air is being dissappainted over more area.
I'm sure the APS design team took that into consideration but I know how things can get overlooked when you have other items on the list to cater to like crybabies who want a turbo kit but don't want to have to modify their bumper. ![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
Also, with the entire mouth of the Camaro bumper cut out, will you be able to see the intercooler fairly easily or will it be tucked way back?
Can you guys remove the firebird panel from the TA so we can get a general idea? That would be fantastic. Then again if it's gonna be black, I guess it doesn't matter.
Could you guys leave the fins of the intercooler bare if requested?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Thanks,
Peter
#1135
Will your Dual fuel pump system be made for US cars as well, I see that the corvette system says it is for Aussie cars only.
Thanks,
Peter
#1136
Originally Posted by peter@aps
The F body dual fuel pump system will suit the F body car only................our development car is a 2000 model TA with a steel fuel tank. Is there any other variant of F body fuel tank?
Thanks,
Peter
Thanks,
Peter
#1139
Originally Posted by Public
Could your guys look at http://www.byunspeed.com/product_inf...dc71013928d151 and tell me if this is possible fit. Goto the product manufacture's site, tons of pics. I dont/wont use brand X anymore and for my street car I wont risk that K member. Flu is hell, get well soon you have a PM.
By the way, my flu is still giving me hell.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Thanks,
peter
#1140
Originally Posted by kwiksilverz
Man, you guys must be getting excited! That's how it was when the clock was ticking down for my GTO kit lol. Also, just wanted to mention that if you have been reading the "other" turbo thread and seen the issues people are having with customs and are getting nervous, don't. All the GTO guys got their APS kits within 3-5 business days from leaving Australia. Just saying this because I know I was starting to get a bit worried I'd have to deal with the same crap as the other guys were and wanted to let you know it isn't a concern
Joe
Joe
Thanks,
Peter
