F Body intercooled twin turbo system - preliminary pricing $5495 inc free delvery
#1142
Originally Posted by NemeSS
a bit of a technical question,
what is the wall thickness of the the manifolds?
and what is the thickness of the mounting flange for the turbo and
cylinder head?
cylinder head?
Peter
#1144
Originally Posted by bigblueturtle
Somebody answer this for me. If a car is tuned to run on a turbo system at 7psi, what good would it be to run a boost controller? Here is what I mean... I know people that change boost levels on their car while out cruising around. Wouldn't that make the car run too rich or lean depending on where the boost is set in reference to the tuning of the car? Why change it once the car is tuned?
http://www.jscspeed.com/index.html?/...m_truboost.htm
Peter
#1146
Can you please elaborate on possible cooling issues?
What kind of temperatures has the car been being tested in? Any problems with overheating? What thermostat is in the test car?
I'm in an area where it is 90 + deg F nearly every day in the summer. I wasn't budgeting for a radiator
#1148
Originally Posted by MY99TAWS6
Anyway sure I can make hptuners work for me. Good enough. Not building a track car anyway just a fun street machine.
Peter
#1149
Originally Posted by Brains
With the car fully and properly tuned for a certain fuel, you can run a boost controller and set it to (nearly) any boost your heart desires. If you change fuels though, you're changing the rules somewhat. You would need to consider the new variables and set up your tune accordingly.
Peter
#1151
Originally Posted by fil131
what size injectors would be needed for 1000HP applications?
Peter
#1154
What will be included in your Twin pump system?
Thanks,
Peter
http://www.airpowersystems.com/guide...-fss01/bom.htm
#1156
Price for this Fuel system? Thanks Peter
Are most of your guys just going to buy the Fuel system from APS or find parts and piece it together.
Just bought my 60# mototron.
Just need everything else.
#1157
Originally Posted by Rubberduck
Peter,will aps supply a base tune for free like the other aussie company will do ?
Tnx
Tnx
Peter
#1158
Originally Posted by 2002 Trans Am
I believe they are, just something to get you going
Thanks,
Peter
