F Body intercooled twin turbo system - preliminary pricing $5495 inc free delvery
Old 07-06-2007, 01:07 AM
  #1301
peter@aps's Avatar
Guys, Here's the link to the APS twin fuel pump system install instructions, enjoy!
http://www.airpowersystems.com/guide...ss01_guide.htm
Peter
Old 07-06-2007, 03:51 PM
  #1302
Big Bird WS6's Avatar
Originally Posted by peter@aps
100% correct, the stock mounts do flex/move around a lot under high torque conditions, hence the supply and fitment of stiffer engine mounts.
Peter
peter you have to see if spohn will fit. i will send you mine if it helps. but that is what i got.
thanks
Old 07-06-2007, 03:56 PM
  #1303
and if i am doing a speed density tune do i nee the maf sensor? and if not do you have a replace ment hose as an opption?
Old 07-06-2007, 08:06 PM
  #1304
MY99TAWS6's Avatar
You don't need a maf with speed density. I also think have to tweak a bit as have 90 mm tb. Minor stuff really.
Old 07-06-2007, 08:07 PM
  #1305
MY99TAWS6's Avatar
What I want to know is which ypipes are going to work. Would prefer a stainless one to a coated one.
Old 07-06-2007, 08:28 PM
  #1306
KWIKKAR's Avatar
Sweet write up on the fuel pump install. How much is it and what horsepower is it rated too.? I'd add the aftermarket fuel rails as well. with 60 injectors
Old 07-06-2007, 10:56 PM
  #1307
fil131's Avatar
Price for the APSLSX-FSS/04 LS Engine Fuel System Peter?
Have you guys come up with the promo price for those of us who have ordered the TT Kit?
I will be running on a stock LS1 for a while.
Old 07-07-2007, 05:53 AM
  #1308
Rubberduck's Avatar
Cool !
Pm Peter
Old 07-08-2007, 04:31 PM
  #1309
peter@aps's Avatar
Originally Posted by Rubberduck
Pm Peter
I'll be back to you soon.
Peter
Old 07-08-2007, 04:34 PM
  #1310
peter when you get a chance answer mine. higher up. thanks
Old 07-08-2007, 05:36 PM
  #1311
fil131's Avatar
Anybody with an answer to my Exhaust question?
I want to run 3" all the way back, should I have a 3"X-pipe?
Should I use mufflers or will they not be needed because the turbo/wastegates will have enough back pressure?
I guess what I really mean to ask is: What is the best exhaust to compliment this Twin Turbo kit?
Thanks,
Filbert
Old 07-08-2007, 05:38 PM
  #1312
JMBLOWNWS6's Avatar
Thanks,
Filbert
I am going to run true duals out the back with a X pipe.
Old 07-08-2007, 05:54 PM
  #1313
peter@aps's Avatar
Will do, just into work now.
Peter
Old 07-08-2007, 05:55 PM
  #1314
peter@aps's Avatar
Originally Posted by JMBLOWNWS6
Awesome instructions Im going to have to relocate alot of things But ill get it done.
I'm sure you will.
Peter
Old 07-08-2007, 05:57 PM
  #1315
peter@aps's Avatar
Is there any way we can get the kit with a screw in IAT sensor?
As far as I know we are using the stock IAT sensor on the F body system.
Peter
Old 07-08-2007, 06:02 PM
  #1316
peter@aps's Avatar
If I could get it with one from them Id rather do that as my list of mods I allready have to do to even install this kit is stacked. Due to the fact I relocated alot of things I do like the threaded inserts on the intake for some meth
I think some of the early LS1 IAT sensors were threaded.............the IAT sensor on our F body just pushes tightly into a rubber grommet, hope that helps.
Peter
Old 07-08-2007, 06:11 PM
  #1317
peter@aps's Avatar
Originally Posted by kwiksilverz
Hey guys, just wanted to post in here and let you know the newest results from my GTO with the APS. The build is as low-buck as it can get for the power it makes and is as follows-
stock bore LS2
Diamond 9.4:1 forged pistons (pistons and rods installed with block in car, just a quick hone, file fit the rings and plopped them in)
scat rods
Stock heads with ARP bolts and GM MLS
stock cam
Patriot Gold springs with Ti retainers
custom dual 3" with magnaflows
Spec twin disk
Devils own progressive kit with larger ID lines and 2 15 GPH nozzles
Walbro in tank with modded bucket and KB BAP
That's it, nothing more, nothing less. As I've posted before, the car put down 795/778 at ~19 psi a couple months back with a 2.5" cat back.
Awesome power and torque from the stock cam and smallish 2.5 inch cat back..............do you have any plans to fit a turbo cam and a larger low restriction exhaust system? If you do I believe you will see another 50-60 rwhp.
third run I completely botched the launch and spun all of 1st and 2nd and bogged down third and it went 11.5@134! This is in a ~4000# car with VERY easy driving (shifts were logged at ~.7-.8 sec!). I just wanted to get a feel for the car before really hammering on it.
Nice MPH Joe, no doubt you will run well into the 10's once you get your chassis/tire combination fully sorted, a big congrats to you and make sure you update us all when you get back to the track.
Peter
Old 07-08-2007, 06:54 PM
  #1318
peter@aps's Avatar
Originally Posted by TNTramair
well i tried takin some measurements but since the BMR K member is installed in a car and the UMI is sitting on the floor it prooved to be very difficult. i can tell you this...the UMI is much more beefier than the BMR. it has alot more material for strengthening the K over the BMR. UMI also has an additional motor mount support that the BMR does not (where the motor mounts bolt to the k, theres 2 tubuler supports) Without having the kit to see where it would need to be clearanced i dont know if it would interfere. looks like the only way to be 100% positive if UMI will clear or not is with a test fit. sorry guys.
Are you comparing the UMI to the latest version of the BMR K Member? From what I understand, there are a number of BMR K members versions. APS has used the latest BMR K member, produced from Jan 07 on.
Peter
PS- Thanks for posting info on the K members, greatly appreciated.
Old 07-08-2007, 06:56 PM
  #1319
peter@aps's Avatar
Originally Posted by BLKWS6
The poly engine mounts are awesome. Ive run those for a while.
Thanks for your feed back on the poly engine mounts.
Peter
Old 07-08-2007, 06:59 PM
  #1320
peter@aps's Avatar
I am planning on doing a 3" turbo back exhaust with this kit,
Would you guys recommend using a 3" xpipe?
How about mufflers? Get some or not?
I have an 02 Camaro Z28 and in my area there are no emissions requirements.
Would it adversely affect my engine if I just ran to an x and then to the rear to some 3" tips? Cuz I know the turbos and wastegates will cause some back pressure.
Peter feel free to chime in on this one too.
Thanks guys.
I take it that you are referring to a true dual 3 inch exhaust system, is that correct?
Quick Reply: F Body intercooled twin turbo system - preliminary pricing $5495 inc free delvery
