F Body intercooled twin turbo system - preliminary pricing $5495 inc free delvery
#1542
Originally Posted by peter@aps
From my earlier post,
''APS did not plan on packaging the GTO BOV's in the F body system as the cost is very high of these BOV's and we don't carry these BOV's in inventory (would push the price of the F body base twin system up much higher than it is now) and the guys who want louder blow off valves can easily customize the twin turbo system with BOV's of their choice.''
Thanks,
Peter
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks,
Peter
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#1543
These turbos are not ball bearing turbos. The vette kit think has more expensive bb turbos but this kit is using conventional turbos modified mitsubishi 20gs. They are still a good turbo very reliable and sure will still spool up plenty fast on our big v8s. You will lose a bit of spool between shifts over a bb turbo though.
So these turbos do not need oil restrictors like bb turbos do and possibly some oil feed only garretts.
#1544
#1546
Originally Posted by Big Bird WS6
sorry peter i ment the upgrade to the other BOV. the one the gto has.
Thanks,
Peter
#1547
Originally Posted by Sixspeed02TA
Peter,
Will there be restrictors placed in the oil feed lines to the turbos? I didn't see any reference to them in the component list or the installation instructions. I've read numerous threads where people were having problems with high oil pressures blowing oil past the internal seals of the turbos. Just wondering how this was going to be addressed with your setup?![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Peter
#1548
Originally Posted by DanZ28
No trick to getting it on, I'm running my stock bellows with my NW TB, it just slid on, it was tight but went on no problem. I think there is barely a difference in the O.D. between NW and stock. Nick W. stated that in a few posts as well, one of the reasons I went with it...![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Dan
Dan
Thanks,
Peter
#1550
Originally Posted by KWIKKAR
WOW 77 pages. Peter you have had your work cut-out for you man. Great Job with everything, I think I would of blown a gasket already. No pun intended.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Peter
#1552
Originally Posted by TNTramair
+1 on a great job Peter keeping up with everyone's questions...good job.
Thanks,
Peter
#1553
Originally Posted by JMBLOWNWS6
So you are saying APS will not sell us the BOV's seprately?
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Peter
#1554
The vette turbos are superior but more expensive true ball bearing turbos. The gto and f body are the less expensive but still proven non ball bearing turbos.
C6 uses DBB turbos, C6 Z06 uses I believe GT35R DBB turbos which are pretty ******* awesome.
C5, GTO, and F-Body all share the same Mitsu 20G turbo.
Would be nice to see GT35R DBB turbos as next years upgrade turbos, but i'm sure the Mitsu will be great as seen on many GTO setups (not yet seen on C5 vette setups)
#1555
Dan, The OD on our stock LS1 throttle body is approximately 99 mm so if you have an after market throttle body which has an OD of 100 mm's the APS speed denisity connection hose will fit up without any issues.
Thanks,
Peter
Thanks,
Peter
So I decided to pull out the digital calipers and measure my own stock TB and the NW TB. Stock TB O.D. is 3.95 inches (or 100mm) and the Nick williams is 4.0 inches (or 101mm). so there is a 1mm or .050" difference between the two for those wondering
Dan
#1556
Ok I stand corrected .Guess was reading the c6 stuff. Anyway yeah those are BB types and 20gs are not bb. I am very familiar with this turbo stuff. Have a big garrett on my 97 talon..sort of a gt30/gt35R cross. and have lots of experience with other mits turbos. The talons use smaller 14bs in the older models. Fairly reliable but at about 100,000 or so miles they are pretty much done but that is fair amount of mileage. Ball bearing gives usually faster spool up and holds between the shifts better. It is also more pricey and don't think rebuildable. I am not overly against the 20gs two of them should still be pretty formidable.
#1557
I was just curious if anyone foresaw a potential problem with the turbos seeing 65+ lbs of oil pressure. I have heard of (and seen first hand) how big a pain in the *** it can be, if you over-pressurize a turbo with oil. I just don't want to be cleaning oil out of my intake.
The only reason I really brought it up was, I was reading through a ton of threads earlier this year....looking at problems people have had in their forced induction setups. Just trying to learn from others mistakes and not duplicate headaches if possible.
If Peter says they're good...that's good enough for me.
#1559
I only ever see around 50 PSI max on my LS1 and LS2 engine. Why would you have 65 PSI oil pressure?
Thanks in advance,
Peter
Thanks in advance,
Peter
#1560
My current motor pins the gauge when cold, and over ~3000 rpm
Stock pump, not ported or shimmed.
It calms down when warmed up though, idles around 45psi hot and 58psi on the money at cruise.
