F Body intercooled twin turbo system - preliminary pricing $5495 inc free delvery
#1581
Originally Posted by calongo_SS
I agree, that's pretty disappointing. I don't see the worm clamps working for people who are going to be maxing out the turbos.
I still want to see them include a Y pipe in the setup
#1582
im just happy theres finally a decent quality kit from a reputable dealer. im not expecting perfection. ill have to swap out those clamps for some t-bolt clamps also but its a small price to pay....just like some cutting and messaging that needs to be done.
gotta love they took the time to produce a new washer bottle though...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://airpowersystems.com/guides/apsgmf-tts01/Section12/184.jpg)
#1583
![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
#1584
Well we have fabbing but we get to keep the air conditioning that is big plus! And air pump if need be.
T bolt clamps are fairly cheap but guess could add another hundred or so to the price. I will for sure be putting them in there especially on the intercooler stuff that sees boost. The air intakes are not as critical.
Would like a list of sizes needed though for the t bolts.
That washer bottle is very nice though! And is the coolant return.
#1585
Oh I also would like to see an aps specific ypipe I still need to know what stainless ypipe I can buy .Might use a hooker non coated for temp but stainless ypipe is what I want to end up with and why buy one twice??
You can't fab up a ypipe that easily locally.
So hoping can get a list of workable ypipes for the system from either guys that have used them or measuring or something.
#1586
well from the pictures it looks like the down pipes are at the same angle as the headers are so its just a matter of finding which down pipe will fit. i have my Kooks ORY laying around so im gonna play with that and see if i can make it work...if not, might end up having to be fabed up.
#1587
Joe
#1590
Originally Posted by MY99TAWS6
Well final instructions are up on the website. Looking over the final instructions.
... I have bought hptuners and am running it already to get familiar with it. While its not simple and overly user friendly I am getting it to work. Planning on speed density tuning likely when go to the bigger engine with big cam and good heads. Leaning now to gt11 type of cam instead of my milder gt 7 lingenfelter cam. And some afr 225 most likely.
I have just ordered 60 pound injectors and have bmr k member ordered up.
Still need to order y pipe and not sure which to get as want stainless ypipe if possible. Also installed nice electric cutout and bought and installed textralia twin disc....
-hptuner
-bmr k member
-60 lb injectors
also need some 918 valve springs and walbro 342 fuel pump. who do you guy use?
#1592
Originally Posted by Sixspeed02TA
I was just curious if anyone foresaw a potential problem with the turbos seeing 65+ lbs of oil pressure. I have heard of (and seen first hand) how big a pain in the *** it can be, if you over-pressurize a turbo with oil. I just don't want to be cleaning oil out of my intake.
The only reason I really brought it up was, I was reading through a ton of threads earlier this year....looking at problems people have had in their forced induction setups. Just trying to learn from others mistakes and not duplicate headaches if possible.
If Peter says they're good...that's good enough for me.
Thanks,
Peter
#1593
Guys, The complete APS F body twin turbo system bill of materils (twin turbo system component list) is now on the link below, enjoy!
Peter
http://www.airpowersystems.com/guide...-tts01/bom.htm
Peter
#1595
Originally Posted by JMBLOWNWS6
Peter, With a meling high volume oil pump your going to see 70 to 80 psi at WOT.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Peter
#1596
Originally Posted by Big Bird WS6
peter answer my question please
post # 1580
thanks
and i am moving next week. will you ship to my new address?
post # 1580
thanks
I'd call some of the aftermarket cat manufacturers (random tech, etc...) and see what they have to offer.
#1597
Originally Posted by peter@aps
The stock APS F body twin turbo system turbo oil supply lines inside diameter is 125 thou..........if you're runing 60 psi you'd need to run 108 thou restrictors and at 90 PSI oil pressure you need to run approximately 90 thou oil restrictors.
Peter
Peter
#1598
Peter, With a meling high volume oil pump your going to see 70 to 80 psi at WOT. Every motor that I have done from LME we always use that pump and that is the typical oil pressure. Heat soaked also. So PLEASE make sure these turbo's can handle that if not let us know what size of orifice we need. Because I am sure I will have good oil pressure.
Peter
#1599
Originally Posted by Brains
My current motor pins the gauge when cold, and over ~3000 rpm
Stock pump, not ported or shimmed. It calms down when warmed up though, idles around 45psi hot and 58psi on the money at cruise.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Thanks,
Peter
