New STS Dyno numbers (T76)
Old Apr 4, 2007 | 01:23 PM
enginjoe's Avatar
This is great. I'm going to be going a similar route. I'm thinking a little bigger cube motor (402) to cut down on lag. I'm also wondering how much fuel system I will need. I'm hoping to put out about the same power, but with the torque coming on a little sooner in RPMs.
Old Apr 4, 2007 | 01:35 PM
JD_Z28's Avatar
Originally Posted by code4
That's awsome, what timing were you running? Did you get any KR? What were your iat's?
Sorry for all the questions but I"m in the process of tuning mine at ~9lbs & I'm getting a little kr.
I'm running right around 19 degrees.
Old Apr 4, 2007 | 03:17 PM
99Z28LS1's Avatar
it does look quite peaky..... but that makes the "power in the seats" feel even better
Old Apr 4, 2007 | 03:33 PM
bboyferal's Avatar
The seat does not lie.
Old Apr 4, 2007 | 03:57 PM
JD_Z28's Avatar
I'm not sure how accurate those numbers are because when they first strapped it down and dyno'd it, it only made 320whp due to the tires breaking loose.
Anyone else with a similar setup have a dyno sheet they could post for comparison.
