balancer spin on crank? will this occur? is it recommended that i drill and pin (key) the balancer to the crank? i wanna run 12-15 psi with a procharger. thanks |
With anything above 7psi we highly reccomend to key the crankshaft to the balancer. 12-15psi would spin the balancer and cause damage to the snout. |
definately pin the crank !! |
X 3...pin it |
who sells a good pin kit i have looked but couldnt find one havent looked real hard but figured someone here could lead me right to it thanks sorry for the post jack hope this will help ya too |
EPP probably sell's the pin kit.They only only install a procharger kit everyother day!!!They are great to talk with also! :drive: |
Originally Posted by HUNTER02SS EPP probably sell's the pin kit.They only only install a procharger kit everyother day!!!They are great to talk with also! :drive: And yes, we do sell the ATI products pin kit and balancer. |
the thing spun my bolt loose. Use a Pin kit. Its hella easy and it works. The tension from the supercharger pulley puts a ton of stress on the damper. And if you have about 500 horses you will ruin alot of things., I called jake a million tme when i did my pin. ( i dont know why its hella easy) |
Originally Posted by BigBenz the thing spun my bolt loose. Use a Pin kit. Its hella easy and it works. The tension from the supercharger pulley puts a ton of stress on the damper. And if you have about 500 horses you will ruin alot of things., I called jake a million tme when i did my pin. ( i dont know why its hella easy) |
I pulled my bolt out by hand from not pinning it. Good thing the balancer was still intact. Definetely get it pinned quick. A broken belt can massacre your engine built when it gets out of line. |
Pin it now. |
Yes do it!!! I ruined the snout of my crank entirely at 12psi on a d1sc. |
© 2024 MH Sub I, LLC dba Internet Brands
