Belt size when using truck manifolds and relocating the alt up top ?
I bought that wonderfull bracket from some guy on here and need to know what belt size you guys are running without the alt down low and moved up top .
LS1Tech Sponsor
If its Smokinhawk and you have stock pulley's, you should need the 73.5. I have underdrive pulleys so i am running the 72.5. Hope this helps!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
