LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   fast 90 or carb'd with elbow (https://ls1tech.com/forums/forced-induction/759503-fast-90-carbd-elbow.html)
Quik Aug 1, 2007 01:06 AM
which is better for a boosted application
a fast 90 or a carb'd with an elbow. if you can give your reasons why or no
trying to figure out which way i want to go
LSInnovations Aug 1, 2007 01:37 AM
Id personally go with a LS2 intake /w 90mm TB...
A LS6 /w ported TB would do the job and cost little to no horsepower as well
Quik Aug 1, 2007 01:55 AM
already have a 90 left over from before
ls1290 Aug 1, 2007 08:14 AM
The Vic intake is better for FI as it will ensure the airflow gets to all cylinders evenly. Even with the FAST or LS2 intakes, cylinders 7 and 8 can be problem sometimes.
Keith
98turbls1 Aug 1, 2007 09:05 AM
I concur, I would go with the carb + elbow combo...
Quik Aug 1, 2007 12:50 PM
thanks guys, looks like carb'd intake. i found info on other site the a fast 90 doesnt like high boost unless the intake is taken apart and expoxied
LSInnovations Aug 2, 2007 02:28 PM
Don't believe everything you read on the internet.
MrDude_1 Aug 2, 2007 02:31 PM
what i find intresting is how "well known" this "problem" is... but if you search, you'll find that noone has ever posted about having this issue.
i think it just stems from it looking like a possibility, since the intake comes apart.
SVC707 Aug 2, 2007 08:37 PM
ok ill speak from true experience of both.. it all depends on your setup. im running a fairly large cam. my motor was built for the blower through lme and they had the cam spec'ed for the setup through cam motion. now with the fast 90 i feathered the gas at initial startup to catch idle. now i turn key and it goes on its own. i also give credit to rick@ synergy for his tuning skills. but he also said the gmpp manifold is more to the liking for my motor. run the fast 90 since you already have it. but if you are able to sell it for a good price then switch. i got a hell of a deal and broke even for my setup. and it was already polished!!!!
© 2026 MH Sub I, LLC dba Internet Brands
