Incon TT cars at N vs. S Shootout
I know Matt Harlan's car was there...but I found pics of three other cars, anyone know what kind of setups these cars have (hp/tq numbers, track times, mods, etc)? Do the car owners post here? Any info would be greatly appreciated.
Thanks,
Mir Naziruddin
Thanks,
Mir Naziruddin
Re: Incon TT cars at N vs. S Shootout
The yellow one is Mike's from huber heights ohio, cool guy. (let me use his garage once too)
He is running about 10psi on a stock bottom end. Ran a best of 10.12@134mph (i think)
had it tunde at detroit speedworks
think he dynoed a little under 500rwhp on their mustang dyno with 7psi?
should be making around 600rwhp with the boost hes running.
another car was a camaro from detroit, dont know much of his set up, think hes still on stock engine, ran a low 11 that day for a new best. also done by DSI.
there was one other twin transam from detroit i think dont know his setup.
and ofcoarse there was Harlans.
The blue formula was mine. Stock motor except ls6 intake, injectors, pushrods, springs and retainers. Car just was retuned at 9 psi on a mustang dyno. Made 503 rwhp and 518 rwtq. 11.5:1 a/f, and it didn't want to make any more power when leaned out to 12.5:1. So we left it.
Car weighed 3860 with driver and FULL tank of gas (which is what I raced it at). Any prizes for most weight?
Best run was on a nitto 17" DR that day at 11.62 at 125 on a 1.95 60'. Let clutch out at 2000 rpm, and stabbed it when it was moving.
Tried the et streets and didn't feel like messing with trying to find the RIGHT launch that the track would take. So I dumped it at 5500 off the 2 step 1 time and ran worse than on DR's. Next time up I tried 4500 off the 2 step and it smoked the et streets, so for the brakets I felt more comfortable with the DR's and a pro tree.
Car has gone 11.2 at 122 on a 1.53 60' and a slipping clutch last fall. 7-7.5 psi then.
Other mods and BMR subframes, ds loop, tq arm, STB, DTS 12 bolt with 3.73's. Hal shocks and drag springs, slp boxed phb, spec stage 4 clutch with new hydraulics, Metco lca's w. relocation brackets, powerslot rotors, and NO weight reduction.
Still have frt sway bar, spare and jack, etc still on the car. Yeah, yeah, I know I need to lighten it. BUT hey, I drove it all the way there and drove it home, and its a fast STREET car that I dont feel like making compromises on . AND I'm too lazy to mess with it at the track anymore. I will change tires, race it and then go home. Either it will run 10.9's the way it sits or not. lol
I too would like to know where the buttpipe was polished . . . looks awesome! And I assume the coil packs have been relocated to under the cowl? That engine bay is VERY nice looking, mine looks like a plumber's nightmare!!
- Dug
- Dug
Mike in the yellow CE runs a Rossler 400 turbo/Midwest convertor and a 9 inch moser with a 3.50 gear. Car weighed #3550 at Norwalk a couple weeks ago.
Tom
Tom
To bad the yellow car is using a crappy looking over flow setup.
Here is a picture of the canton over flow tank:
http://photos.yahoo.com/bc/oms_guy/v...c=ph%26.view=t
Gary
Gary
I've seen the Canton work done on LT1 oil pans.
I wouldn't buy anything made by Canton if my life depended on it.
Why you would even mention that is beyond me. Those bozos don't deserve to be mentioned on a quality board! PERIOD!
I don't normally get emotional like this but those pans leak like a 4 year old welded em!
