Twins location in an f-body. Starting to brainstorm new set up
Hey everyone, just trying to get some opinions from you guys. Right now im getting a little tired of the cons that come with my twin kit. the no AC is pissing me off a bit. Anyway i want to gear my car more towards a 100% street car for next summer. It still was a total street car this summer but i didnt drive it as much as usual due to no AC and not being real enjoyable in the hot summer months, etc. So i am brainstorming a new set up.
I like the new BMR turbo k-member. Im thinking that in addition to a C6 manifold on passenger side and i will snake pipes around the AC compressor. How the other issue i am coming into is a mounting location for the turbos. There arent many options for twins that will gravity drain and keep AC. Mostly up and center with rad moved forward totally or rad moved up a bit and place the turbos out in the battery and fuse box compartments. However i think i might run into an issue with how far i can move the stock rad forward with the AC condensor on it as well..... So what do ya think, any opinions as to a solid place to mount these 2 suckers, will be staying T3 so that will help some. I want to keep them in front of the engine....
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Word. I'm doing the same thing. I'm going to buy a BMR turbo Kmember and do twin61s now. I'm gonna drop A/C anyways for now, I might put it in my new project car, the 86 GT that's getting my LS1 and T76
Also getting rid of the oil pump, I hate that thing too. Plus you're relying on it not to go out or else your turbo seals go
I'm going to cut my cross section out to stand a nice new radiator straight up so I can put the turbos up top to gravity drain into my timing cover like the big boys do it.
I'm gonna try to keep my A/C as long as possible but it's not gonna last for long I don't think. Plus it's almost winter
Originally Posted by Slowhawk
Probly cheaper to sell your kit and go with an APS kit.
Dont want APS, no offense but i dont like the turbos in that location and i hate the fact that you can hardly hear any turbo noise in their kit. Plus i like the fact of my intercooler up front and i already have my WGs, BOV, intercooler, oil lines, flanges, turbos, etc. WIll be easy to just redo pipes. I want my turbos seen in the engine bay being a street car. Where do you think is a good place to mount em?
__________________
How much of a job is moving the fuse boxes? Where exactly are you guys moving them? And in that spot, the rad must be moved forward or else i guess you could leave the rad but would have a fun time with the upper hose and ABS. Anyone know how much you can move the stock rad forward with AC condensor on the front of it?
__________________
Nah, im staying twins. I have all the goodies, just want to re-do my kit. Im really liking the idea of turbos in each corner like Tiago and Fitz, but whats required to move the fuse boxes and what do you do with overflow/cold pipes off turbo?
__________________
Yea, but where up high is the question. A good spot is hard to find and usually requires a lot of modifying. The thought of Procharger is also crossing my mind just for ease of use and reliability, etc. I dont know.
__________________
Cut your cross supper, stand a nice new radiator straight up where the cross section went. Have 1x1 square tube welded onto the cross section to keep the stability that works just fine. Look at the pics closely.
I'm going to drop A/c and try to fit it in later after I get the setup running. I can probably fit a small condensor somewhere in the front of the radiator somehow...I just know it. Gonna figure something out. Buying a welder soon to do my own work from here on out. No more waiting on other people, other than shipping endless parts Oh well, it's my life. What do you think? Would any of this work for your setup? You have all of winter and spring to figure the A/C ordeal out. We need the new BMR turbo KMembers soon! The downpipes could go through the extra space on those kmembers, since the truck manifolds (and maybe a c6 mani on the pass side)sit up higher. We can make this work.
Matt
See the only issue i see with that is moving the rad forward. Its not moving it forward thats the problem, its moving it forward and fitting my AC back in front of it that would be the problem. Right now im seriously thinking of switching to a procharger. It seems the most sensible considering what i want. 4xx cubes and F1a might sound nice
__________________
