stock cam vs boost cam in stock motor
On the dyno the power dropped down after about 5000 rpm I think the stock cam is the issue here , I seen nothing but boost cams in this forum and its year end so the x-mas list starts.
This is 10# what do yeah thing? [IMG][/IMG]
LS1Tech Sponsor
Looks like boost drop or floating valves. We ussually recomend unpgrading the valve springs on stock Cams running boost.
Here is a graph of a small Cam,big motor,14lbs of boost. As you see peak power is very early but flatlines.That is a cam that is too small for the setup.
No over boost shutdown, just a manual boost controller and the gauge stays there the first pull we did it was mid 10's a/f and you could hear it breaking up so we took fuel out of it, we did like 13 pulls starting at 7# up to 13# and all pulls power tapered off. I'm having the dyno place e mail me the pulls I have then on paper somewhere?
So what should I do drop boost and all some timing up there
Thanks for the help
Oh shoot the log i just did was a pull in 3 and 4th gear and 3rd gear i got the knock at 4000 to 6000rpms (tire spin) and forth gear 4000 to 6000 rpms no knock! What should I do, Ha ha 3rd gear roll ons 4200rpms (70mph) when tires are cold it spins the tires 1.5* of knock then it fades out. What is wrong with us, boost is worse then crack always want more
