How necessary are dual valve springs on 12 psi ls6 heads
How necessary are dual valve springs for a yellow spring ls6 head engine? I'll run up to 12 psi on 9:0-1 comp. Replacing the pushrods for sure.
Thanks
Thanks
I would still upgrade.. It's cheap insurance like Avengeance said... You'll really be kicking yourself with you float a valve and have to replace a piston... I believe a 918 spring has more seat pressure than the ls6 spring and I still don't think I would run them... These are just my belief... I know KP said that he ran a single spring (don't remember which) and he ran it into the 10's... I won't try it because Kevin has the luck of a person that wins consecutive lotteries... He's been very fortunate with his setups...
I just assumed I had to use them but have read many people and several kits don't have/include them. I think I'll grab a set.
Where are they $120. All I've seen have been in the $200 range.
Once that boost gets into the chamber, it pushes against the valve, so you need a stronger spring to counteract it. There is a formula you can do to figure what your seat pressure is with XX boost.
