Building a block for FI
Old Nov 19, 2007 | 07:30 AM
rufretic's Avatar
Default Building a block for FI
As some of you know, I'm going to be needing a new block. This is a first for me so I would like to get a discusion going on what makes for the best, most power/reliable engine. I'm pretty sure I want to use the lsx iron block, just not sure how to size it. Is it always better to go bigger? Example: say I spin my blower the same(max rpm) with a 346 and a 408. If I understand correctly, the 408 will make much less boost but how will the power output compare?
Old Nov 19, 2007 | 07:43 AM
TAQuickness's Avatar
the basic principles are the same - more air in and out = more power.
You really need to define all your goals in order to determin what combo will give you the desired results.
Old Nov 19, 2007 | 08:00 AM
rufretic's Avatar
My goals continue to grow so that's a hard one. I originaly thought I would be happy with an 11 second car lol. I'll just say 800-1000rwhp, mid 9s and have room to grow when I want more. Also be strong enough to hold these power levels for more than just a few passes.
Old Nov 19, 2007 | 08:40 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Are you going to run a D1SC?
Old Nov 19, 2007 | 09:12 AM
rufretic's Avatar
Yes, yes I am.
Old Nov 19, 2007 | 09:36 AM
Websy21's Avatar
Many will say that the D1 is too small for the 408 but this was the combo I was going to run anways as there are a few on here closely aproaching 800rwhp with this combo. I ended up picking up a barely used turbo kit instead for a great deal otherwise I'd be D1/408.
The F1 matches up better if you want room to grow, unless you aren't happy with 750-800rwhp I say go with the D-1. You can always buy the F1 head unit and sell yours later if you want to upgrade. I see you already have the FMIC so you are golden there.
Good luck man
Old Nov 19, 2007 | 10:36 AM
vette#3's Avatar
The only issue i see with growing after running 9sec pass ,weekend in & Weekend out ,is Money ,it takes alot more money,I mean sure Alot of people on this board & Other boards can build a motor & Put an d1,f1 & Run in the 10s ,Low10s allday long ,then once u get tired of that point ,trying to get it to run faster is really gonna take alot more money ,something i have a hard time with myself ,is to try to be content with running 10sec pass Day in & Day out ,& Calling it a day ,I know there are some guys on the board running in the 9s,8s ,in the qrtr mile ,But i personally am not willing to chop up my street car to & To throw out all the Xtra $ to go a sec quicker
Old Nov 19, 2007 | 11:08 AM
rufretic's Avatar
Good luck man
That's the reason why I started the thread. I'm staying with the D1. With that said, how much is there to be gained with a 408? I made 680rwhp with the 346@13psi and still can go to a smaller pulley without issues. I was using the 4.25 pulley. I'm thinking I can build a strong 346/347 and hit it with 20psi making well into the 800s. But is a 408@10psi going to make around the same power and be more reliable?
Old Nov 19, 2007 | 11:16 AM
rufretic's Avatar
Well, I am going to have to shell out a good amount of money already. Since I was so close to 9s already I don't think it should be too hard to get there with a new block, I'm just not sure how reliable an engine can be at that power level no matter which block I choose. That's why I need help making a well thought out choice. Is there a such block that can make say 900rwhp reliably? If so, what's best, more boost or more cubes?
Old Nov 19, 2007 | 11:22 AM
LS1Tech Co-Founder
Maybe a goofy question, but is it harder to keep a blower belt on a big stroker?
If you run a 346-364ci (LS1 - LS2), and boost it 20 psi, you will be running some race gas. I went 9.40@143mph with 18 psi and a 8:1 348ci a few years ago.
Old Nov 19, 2007 | 11:32 AM
platinum1's Avatar
lsx block and it will last you forever
platinum1's Avatar
i am going to run the lsx with my f1r
Old Nov 19, 2007 | 11:57 AM
rufretic's Avatar
Not sure, I don't see any reason why it would slip more but I'm asuming less boost because the larger engine moves so much more air.
Race gas is not a problem, I don't put a lot of miles on it.
Old Nov 19, 2007 | 12:09 PM
427's Avatar
427
The LSX block will be strong enough for anything you do for years to come, but you pay a weight penalty. The LS2 block stock will drive your car into the 9's without trouble, but it may not be enough to turn the dyno to 900rwhp+. Some rwhp numbers depend on your driveline and the type of dyno used.
The more air a sc delivers, the harder it works, boost psi is secondary.
Kurt
Old Nov 19, 2007 | 03:23 PM
Bryan @ Speed Inc.'s Avatar
louis, for durability and price, i would go with an iron 370. especially since you seem partial to stock'ish cubes.
we actually did an LSX 370 with a D-1SC for a customer not too long ago.
Old Nov 19, 2007 | 03:25 PM
LS1Tech Co-Founder
If it were me I'd run an aluminum LS2 to keep the weight off for mid to high 9's, but a truck block-based shortblock would certainly be up the task.
Old Nov 19, 2007 | 03:28 PM
98Z28MASS's Avatar
I say ls2 402 stroker with the best forged internals you can afford.
Old Nov 19, 2007 | 03:34 PM
MonkeyBoneSS's Avatar
How was the out come on that set-up? Would like more info for sure, if at all possible.
Old Nov 19, 2007 | 03:53 PM
4.030 inch bore, and an aftermarket crank with a stock stroke.
this customer has to pass the sniffer when he goes in for emissions. he actually puts his stock exhaust mani's and cats back on the car to get tested. so it's on pump gas, low boost, and mild heads/cam. It made over 580rwhp, but it was very limited.
i'm sure the motor louis will end up with will be a lot nastier.
Old Nov 27, 2007 | 02:59 PM
ChiTownSS's Avatar
LSX block with forged internals. Stroke it, charge it!
