Location for WG
Old Dec 3, 2007 | 12:58 PM
Broke EF's Avatar
Like it was hinted at in the post above me, it becomes more important with less tollerance to over boost. You can really have it anywhere and compensate with a bigger gate, but thats not really best. For an example (as far as I know) if you had a 76mm with a 38mm in one bank, there is a good chance that the exhaust from the other bank will make it creep. You could correct the problem with a larger gate, but its kind of a mediocre fix. So the best way given the circumstances is to try to have it centered in the collector right before the flange.
Sean
