Best Location For 02's On a turbo car. Should i weld them on the downpipe or the crossover.. Im going to start making my downpipe and need ideas.. Yes i did try the search.. |
Down pipe. |
My kit came with the bungs in the downpipe after the turbo's. |
Wide band in the DP. (8 inches from Turbo) Narrow bands inthe Cross Over (if Kepping them). |
Originally Posted by Josh @ KYTP
(Post 8326301)
Wide band in the DP. (8 inches from Turbo) Narrow bands inthe Cross Over (if Kepping them). Can I ask why 8 inches? I was wanting to put them ferther back, out of sight. Thanks - Ron |
heat. |
Originally Posted by TT402LS1
(Post 8328559)
Depends on setup.I like one in the crosspipe and one in the downpipe if a log manifold is used.If they are a single pipe off each bank then put them there.I've had 2 cars run like crap.Both of them had the 02's next to each other in the same pipe.As soon as I split them the cars ran 100% better. |
So if youre doing say a truck manifold set up, you would run youre narrowbands just out of the collector of each manifold (a couple inches away?). And then the wideband minimum (is there a max distance) from the turbo in the downpipe? Just clearifying. Thanks, Sean |
Im going to try one on the cross over and one on the downpipe. |
just make sure the 2 front O2 sensors are the exact same distance from the header flange, as in not one in the collector and one in the DP. it will severely mess up your fuel trims and the car will not sit at steady state cruising |
So is there a set distance from the manifolds? Or just the turbo because it creates so much heat? Thanks, Sean P.S. Sorry for hijacking youre thread a lil |
Originally Posted by Josh@MASPORT
(Post 8333607)
New to this too but I think what they might be getting at, correct me if I am wrong, is narrow bands in the single header collectors at same distance from each header and the wideband in the down pipe atleast 8'' from turbo. |
there really is no set distance for the front 02 but the closer to the header the better, just make sure they are the same distance from the header so they read the same thing at the same time, also the wideband should be close to the turbo but not to close, im sure you can make an educated decision of where you want it to keep it from getting too hot, remember that the N/A guys have theres in place of their rear 02s etc, many feet from the header |
why are changing the locations? when is it going to be running? |
Originally Posted by SELLSZ06
(Post 8342900)
why are changing the locations? when is it going to be running? Im welding a new downpipe it wouldn't fit when i tried installing it. |
Can i only use a wide band with a stock pcm? or is stock pcm programed to only read narrow bands? |
I had my narrow bands in my downpipe and man did it run like shit. When I went back to single turbo. So I put them right after my headers one on each side and bam it runs just as smooth. But when I was twin I had them in the downpipe and it ran good. |
| All times are GMT -5. The time now is 06:21 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
