Rear-Mount Setup Questions Alright, I'm seriously thinking about fabbing up a turbo setup for my new T/A. I'd be happy with 450-500rwhp. I was thinking of running a rear-mount setup with a Holset HX55, problem is I can't find anybody who has actually ran one on a LS1 car. From the info I've found they have 70-72mm compressor inducers. Also, before someone says it, I can't afford a Precision or Turbonetics turbo, I have to work on a tight budget here(college is rough). I'd like to get some opinions. Should I just go for it and try it out? What do you guys think? |
C'mon, no opinions guys? |
Yea if you are really looking for just those numbers.. go with an STS... for the $ and for your goals.... you will be just fine. |
Master Power t-70 was about $600 I've had no problems in 3 years, but others have had some difficulties. The range for rear mount seems to be the 60-1 (base STS kit) up to the 76, and I know a few that have gone larger. On the turbine side I think most are running a P-trim with an A/R from .68 up to .96. |
Originally Posted by 2002ws-6
(Post 8783614)
Master Power t-70 was about $600 I've had no problems in 3 years, but others have had some difficulties. |
Originally Posted by Destru6969
(Post 8788941)
I think I'm going to go front-mount now because the fab work will be about the same difficulty, but less in materials.. |
ya...sts kit for instant gradification....front mount for somone with skills and patients....if you are anything like most of us....we want everything yesterday....haha either way good luck!!!! |
Originally Posted by ls1leadfoot
(Post 8791670)
2k is a realistic number. youll be ok . alot of dudes think they can go turbo for 500 bucks. 2k is what youll problly spend to fab a good system, new turbo, wastegate, pipeing (hot and cold), oil lines, couplers, and the 35 other things you never think about. BUT to make reliable HP you need to spend aliitle more around 5 to 6 hundred on getting some more fuel to it. |
well thats good to hear....make sure you keep us updated with pics and vid of the build!!!!! good luck |
| All times are GMT -5. The time now is 01:42 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
