Poll: How much Fuel press at WOT on boosted cars
Re: Poll: How much Fuel press at WOT on boosted cars
Incon TT at 5.5 psi
Walbro gs340 (not hotwired)
MSD 50 lb injectors
stock regulator, no adjustment
62 psig at idle and WOT
Gary
MSD 50 lb injectors
Gary
Doyou have a rising rate FPR (if not it would be a good idea to get one).
With one your Fuel Pressure should be your base FP (measured vs. atmospheric - reference line pulled off) + boost pressure.
You can set your base to whatever you want - you should probably set it as high as you can while still maintaining fuel volume (fuel pressure at max boost).
