F-Body D-1SC 8 rib tensioner pulley needed!
Old 04-05-2008, 02:25 PM
firehawk618's Avatar
Default F-Body D-1SC 8 rib tensioner pulley needed!
Anyone got one?
I read something about using an OEM type that works fine....any ideas what application that might come off of so I can look it up.
Old 04-05-2008, 04:53 PM
DeltaT's Avatar
Search the web for Dayco HD Tensioners and Pulleys, there's a .pdf out there with the pulleys and dimensions on the back couple pages. I use 2 of the smooth ones and 1 8-rib and they are nicely built with double bearings and are about $40 at any Dayco dealer.
Jim
Old 04-05-2008, 10:51 PM
I tried looking for the tensioner pulleys from dayco. I could not find any double bearing ones. Anyone please help me with the part#?
Thanks.
Old 04-07-2008, 10:07 PM
Found a Dayco HD pulley that worked perfectly! About 10mm larger in diameter but width was fine. Only thing is the bearing offset is slightly different so the belt does not ride perfectly in the center of the pulley. Might modify the shaft that the pulley rides on to bring the pulley a tad closer to the bracket.
Quick Reply: F-Body D-1SC 8 rib tensioner pulley needed!
