Tubular K member for C6 manifold?
Which tubular K member do you need for the C6 manifold to fit reverse on the passenger side? Is a regular BMR ok or do I need the turbo one?
Thanks,
Brad
Thanks,
Brad
You don't need to reverse the manifold! Use the passenger side C6 manifold on the passenger side of the F-body. Then curve the pipe that comes off the manifold around the K-member tubes outside the A/C compressor.
