6.5 diesel turbos would 2 of them work 4 5300
Old 04-26-2008, 04:29 PM
ricehungry454's Avatar
Default 6.5 diesel turbos would 2 of them work 4 5300
i was wondering if anybody has used these 6.5 diesel turbos before and what are youre thoughts on them
Old 04-26-2008, 05:28 PM
383lt1impala's Avatar
u talkin like ones off a hummer? i wouldnt diesel turbos max out at low rpm am i right? plus those are factory turbos.
Old 04-26-2008, 07:15 PM
its a budget build and im using two of them alot of people use diesel turbos like the s400 thats a diesel turbo
Old 04-27-2008, 11:32 AM
lt170chevelle's Avatar
they will work fine..if its the one i am thinking of you could probally use just one and be sufficient. thing about diesels is that there exhaust housings a/r is usually huge compared to gas motor ones.gotta remember diesels dont have throttle blades so they move alot of air.
Old 04-27-2008, 12:34 PM
Dragframe's Avatar
Your not taking into account most diesels also only spin 3k and not 6k rpms.
Most diesel turbos thrown on a gas engine are usually SMALL. All these s400's that people are using are using on semi's (secondary turbo on a cat TT).... 12 something liter diesels.
Old 10-24-2008, 12:22 PM
Fullboost's Avatar
The 6.5 turbo is a super small IHI turbo. You have to remember the 6.5 motor is a turd and needed a small turbo unlike the newer diesel trucks.
