Truck Manifold Hot part
Old May 11, 2008 | 09:28 PM
JerikSS's Avatar
Default Truck Manifold Hot part
Does any one sell the truck manifold hot part that goes from the manifolds to the turbo? Every one routes it the same has anyone done some extra ones for sell?? I need to change my set up and I fear my welding skills are terrible. I am only looking for that part for a single turbo???
Old May 11, 2008 | 09:37 PM
ttranssam's Avatar
try kentucky turbo...badass sponsor here, he has what you need
Old May 11, 2008 | 09:54 PM
JerikSS's Avatar
Thank you but I am looking for something like this picture minus the turbo and waste gate.
Old May 11, 2008 | 09:57 PM
ttranssam's Avatar
um...he sells just hot parts too and id say thats pretty much ***** on same thing he sells? wouldnt doubt it if he made that one
Old May 11, 2008 | 10:30 PM
SScam68's Avatar
Looks like Frcefed98's setup. Homemade
Old May 11, 2008 | 10:40 PM
Sideways240sx's Avatar
yea, that pic is of frcfed's. Josh does sell just hot parts. Problem is if what ever hot parts you get put the turbo in a little diff spot, then the cold pipe from turbo to ic, may need a little modifying. Not a big deal, but may happen.
A little search and i found this thread.
https://ls1tech.com/forums/showthrea...929&highlight=
Your looking at 1250 for crossover pipe, and 3 inch dp. It will have wastegate flange's and should be rdy to just bolt ur turbo on.
Good luck, Chris
Old May 11, 2008 | 10:57 PM
Josh@KY-Turbo's Avatar
Yep the above pic the Jer's setup.
I do offer hot parts like Chris stated the above. I can do a Cossover only if that is all you want. Just finished up one today for a customer.
I will do the crossover only for $950 shipped.
-2.5" Mild Steel
-T4 flange
-38mm WG flange
-Narrow band O2 bungs
Let me know.
Old May 12, 2008 | 12:39 AM
Q8CamaRo's Avatar
josh@KYTP is the way to go
good luck
Old May 12, 2008 | 12:46 AM
z06kilr's Avatar
ive got a complete PT88 truck manifold kit for sale for $3500 all mandrel, I/c 60mm wastegate, 50mm bov etc.
100 miles on kit going to build a twin setup.
Old May 20, 2008 | 01:45 AM
JerikSS's Avatar
If you remove the alternator. Is there enough room to run an exhaust through there to the back?
Old May 20, 2008 | 02:38 AM
Not with 6.0L manifolds. Not enough clearnace with the steering shaft. The A/C has to go anyway. My hot parts run the 3" DP over the k-member onthe passenger side. I can have a Chrge pipe and DP done and ready to Ship in around 2 days form the order right not. I have everything needed in house for the following:
-2.5" Mild Steel Charge Pipe
-T4 flange
-38mm WG flange
-3" DP
-WB O2 bung
$1250 for the set.
$950 for the charge pipe alone.
