Question for my friend.... TTI Street kit/WG Issue
My buddy just installed a TTI street kit on his car. It has the 38mm Delta gate. He got it all buttoned up and took it for a tune but they said that his Wastegate was too small and the car was continueing to make boost and not stopping. We are a little dumbfounded as this is the gate that comes with the kit that has been in production for many years. The car is tuned enough to drive and it seems like the boost is not steadily climbing, we only see 6 psi. The tuner said he needs a 44mm wastegate but we are not finding the issue with this one and are wondering if it is an issue at all? What gates are you guys running with the tti kit and any issues? Its the 60mm kit on a stock engine looking for 8 psi. Does he probably need a bigger gate or should this Delta 38mm work just fine? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
